horsman_f3's Avatar
Send a message via Yahoo to horsman_f3
1987 944s Cold Start / Performance Chip
I bought a 1987 Porsche 944s last spring. Since I bought it, it will not stay running until its been warmed up. I was told that is because of the chip that is installed in it. Could that be true? Or, the DME is bad? I have been thinking about pulling the chip to see what kind it is and looking at the solder joints of the DME.. Any feedback would be greatly appreciated!
What are a good, safe, and recommended performance chip?
Cheers!
Old 12-11-2014, 11:03 AM
Toofah King Bad
Rasta Monsta's Avatar
I wonder if the prior owner "deleted" the idle air controller. It's one of those "performance modifications."
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-11-2014, 12:55 PM
horsman_f3's Avatar
I will go look and see if I can see it..
Old 12-11-2014, 01:57 PM
I have a Wilks race chip in my 85.5, and it starts and runs well in below freezing temps, however the PS pump howls a small bit when cold.
Old 12-11-2014, 02:06 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
horsman F3:
Recommend replacing Oxygen sensor O2 and adding a Fuel Treatment (Chevron Techtron).
Remember your need 93 Octane or it will never run properly. Later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 12-11-2014, 03:56 PM
horsman_f3's Avatar
I run 93 Non oxy.. When its warmed up it runs like a dream. Or is it 91?? I know whatever it says in my gas lid, its what I get at the pump.
Old 12-11-2014, 06:09 PM
guru944's Avatar
Why no oxygen sensor? The DME is adaptive and needs it. Suspect defective sensor...later...
Guru944
Old 12-17-2014, 12:15 PM
horsman_f3's Avatar
If you referring to my 93 Non Oxy comment, Im referring to the fuel I run in it. Its 93 Octane Non-Oxygenated gas.
Old 12-18-2014, 12:20 PM
