That Guy
Techno Duck's Avatar
RMS install tool P234 rental offer
I bought one of these RMS ( rear main seal ) install tools on a whim a few months ago (price was right!), figure i put it too some use and rent it out to those who may need it.
This is tool P234 for installing the RMS on 944, 951 and 968. Cost new is about $130 and is likely a tool you will use once, then never touch again. I borrowed one a few years ago when i did my clutch and everything installed easily... no messing around with a PVC cap.
Using this tool with the Elring RMS i think gives you the best chance of having the seal install correctly and not leak. RMS replacement is not something you want to do twice.
Rental fee is $20 to cover my shipping expense, it will be sent out USPS which is basically 3-day air anywhere in the US. You must leave a $130 deposit on the tool before i send it out to cover my cost in the event i never get it back or you some how manage to break or damage the tool. When i get it back, i will refund you $110.
Pelican link for the P234..
Pelican Parts - Product Information: PEL-TOL-P234
I just ask you be considerate and dont hang onto it for more than a month while you slowly take apart your car.
Let me know if interested.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 04-01-2012, 12:43 PM
FRporsche's Avatar
Very cool of you to offer!
I wish I had that tool - doing the RMS on a 968 6-speed is a *****. Are you sure it works on 968s with that 2-piece bellhousing?
'87 951 | '87 951 | '87 944 | '93 968 | '84 944 | '82 911
'82 300TD | '77 6.9
Old 04-02-2012, 01:07 AM
kwikt 911's Avatar
I have the same tool. Yes it works great on my 968. Made rms install toooo easy especially with the motor still in the car. As you know space is very limited.
Old 04-02-2012, 06:45 AM
Think I'm going to need this, can work out the deposit payment details with you later.
Seems like you've maybe done a few of these. Clutch has relatively few miles on it, 2-3K but I've got to check out the RMS as it seems to be leaking quite a bit.
I'm assuming the clutch has to be removed but not the flywheel to get to the RMS, won't know until I get in there. Are any clutch alignment tools needed when putting things back together ?
On a pain and annoyance scale how would your rate the RMS job compared to the Rod bearings/pan gasket or the T-bar replacement?
Thanks,
Brian
Feel free to e-mail directly at bfugok@ptd.net
Old 04-27-2012, 06:13 AM
That Guy
The flywheel has to be removed also for access to the RMS. Basically it is the last step of a clutch job before reassembly can begin. There is a clutch alignment tool, but if i remember right one from a Ford works and is readily available. Not sure what happened to the alignment tool i had but i am sure someone has one they can loan / give you between here and RL.
To rate the RMS / clutch replacement i would have to place it under rod bearings and torsion bars.. maybe a 6/10 instead of a 8/10. It is basically all labor taking stuff off the car. In my opinion the biggest PITA is always taking out the transmission. No matter how many times i have done it, even with the car on a lift i hate doing it.
I have the RMS tool available to mail out, just PM me if you think you will need it and we can figure everything out.
Jon
Old 04-27-2012, 07:08 AM
tool rental
Hi Do you still rent the rms tool? Does it work fot a 08 Cayman s 3,4? Let me know at pjscrs@gmail.com. thanks im also in pa. PAUL
Old 12-28-2014, 12:08 PM
Andrew Gawers' Dad
CHICKS's Avatar
A literal 1 second google search says no, this will not work on a 2008 Cayman 3.4.
Old 12-29-2014, 04:44 AM
Toofah King Bad
Rasta Monsta's Avatar
lolz
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-29-2014, 09:27 PM
911tracker85's Avatar
got a PM reply from techno Duck. he does not have the tool any longer.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 12-30-2014, 04:57 AM
