overkill's Avatar
Send a message via AIM to overkill
Question,...
How the hell do I get the injectors off the fuel rail and the manifold? Are they just pressed in or they screwed in? Whats the deal?
{1987}944S - (SOLD).
Old 10-19-2002, 11:08 AM
Scott R's Avatar
Should be a couple of 10mm holding the rail to the head. Then they are pressed in. They do get stuck over time, and you may have to carefully pry up on the rail a bit. Also there are retaining clips between the injector and the rail itself, these just slide off.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-19-2002, 11:16 AM
SoCal Driver's Avatar
After removing the rail and injector assembly; pull off the clips Scott describes FIRST.
Gasket sets are available at Pep boys for less that $2 each.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-19-2002, 12:06 PM
overkill's Avatar
Cool will do,... thanks.
Old 10-19-2002, 12:07 PM
overkill's Avatar
WhaaaaHOOOO, I got my intake manifold off. The first thing I saw was oil caked up on the inside of the manifold and in the intake ports on the head. Is this related to the bent valves(which i dont think) or is this somthing else? Let me clean up and gather myself and I will take some pictures for you guyz to look at.
Old 10-19-2002, 04:41 PM
Oil in the intake is coming from the breather. Means lots of back pressure from the engine. Possibly even blow by from the pistons (rings).
Oil down on top of the intakes is bad guides and, as a consequence, worn valve stem seals.
Pictures?
Old 10-19-2002, 05:05 PM
overkill's Avatar
Im going to get you pictures in a minute. there is oil in the manifold and there is also oil on top of the intake valves. Hold on,... im gonna get pictures
Old 10-19-2002, 05:14 PM
overkill's Avatar
Pictures,... Theres oil everywhere. So,... I can use Simple Green, water, and a air compressor to clean the manifold right? Now, whats the deal with the back pressure? I remember reading that the NA cars use back pressure to gain on HP, this is to much back pressure right? Does this mean that there is something wrong with my exhaust?
Old 10-19-2002, 05:59 PM
