930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
9201 or should i buy cheesey tensioner tool?
Doing a early motor and late motor and Im gonna have to tension belts at some point. Will the cheaper belt tensioning tools work as well? It is 2015. Thoughts or feedback.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 01-16-2015, 01:42 PM
Diving in 911
Krikit
I just got one of these and Im going to test it against the Porsche tool. I'll let you know what I find.
1976 911s Special Edition Turbo bodied IROC tribute
2002 911 Carrera C4S
1971 914 1.7 Tangerine
1989 964 Coupe/1992 964 Cab
1987 928s4 Granite Green
Old 01-16-2015, 06:03 PM
Patrick
pfarah's Avatar
Or one of these (my Christmas present)...
1984 944 NA, constant tinkering
Old 01-16-2015, 06:53 PM
Toofah King Bad
Rasta Monsta's Avatar
My goodness, the instructions to that thing. Yikes!
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-16-2015, 11:57 PM
Patrick
pfarah's Avatar
You got that right!
Old 01-17-2015, 03:25 PM
Andrew Gawers' Dad
CHICKS's Avatar
I used the 928 style arnnworx tool. Used it like 10x and no problems.
Old 01-17-2015, 03:48 PM
Just thinking out loud
mattdavis11's Avatar
91 FJ80
84 Ram Charger
Old 01-17-2015, 04:04 PM
FLYGEEZER's Avatar
Been doin' mine as the mattdavis 11 post shows, The 90 degree twist method. R&R belts every 30,000 miles/5 years. No problems....ever!
Edgar
1984 Porsche 944 bone stock
1995 Mercedes E320 wagon
1970 Honda CB350 mint!!!
Old 01-17-2015, 05:22 PM
Custom User Title
mikepellegrini's Avatar
Yea! +1 for fingers. Works like a charm.
83 944 NA - Black on black
86 951 - Red
97 Ford Expedition
He who hesitates is lost.
Old 01-17-2015, 07:32 PM
Northern Motorhead
wildcat077's Avatar
I picked up the same tool last Summer ,great to have around the shop !
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 01-18-2015, 08:42 AM
h20cooled7's Avatar
Ok so I can do 90°s twist on the cam and balance shaft belt in the longest span of belt?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 01-18-2015, 09:51 AM
Toofah King Bad
90 for cam belt, 270 for balance. JohnAZ also has a good method for testing tension after using the 90 degree method. . .put on some latex gloves and try to turn the water pump pulley. If it doesn't turn, belt is too tight.
Old 01-18-2015, 10:18 AM
FLYGEEZER's Avatar
+1 on the water pump & rubber gloves ! Thanks Rasta, I left that important part out.
Edgar
Old 01-18-2015, 10:23 AM
winter-hater club member
nynor's Avatar
yup, after doing several of these on 944's (at least a dozen), i've used the 9201, the krikit, the arnnworx tool, and my fingers. i've checked all of the above against the 9201 and found them to be satisfactory.
it is my opinion that the 9201 was an overkill solution to some costly belt failures, when the 944 first came out.
it isn't voodoo.
"COOL PRIUS!" - Nobody Ever
Old 01-18-2015, 10:28 AM
JBC JBC is offline
JBC's Avatar
I recommend having a tool to measure. I like the Annworx tool myself. I think you need to know the numbers AND see what that looks/feels like. I'm sure experience will get you close without a tool but I'd rather get the belt into the proper tension by measuring it. I'm getting ready to do my 1500 mile retension after a new belt installation. Having the tool to get the tension exactly where the engineers said it should be, ensures that the set up is within limits, etc. Otherwise, it is a "good guess".
Old 01-19-2015, 12:07 PM
Bradical's Avatar
The 9201 tool actually has an extra function that you don't read about very often- not only does it mesure calibrated belt tension in nm, but much more importantly it takes the responsibility of timing belt failure off of Porsche and puts it onto the last mechanic who touched the belts.
Old 01-19-2015, 03:28 PM
^^Hahaha
When I put my camshaft back together and put the timing belt back on, I literally just used a long screw driver on the tensioner (I had an 87 with the "auto tensioner") to pull it tight then just re adjusted it until I was happy with the 90 degree test. Worked for me, drove it like that for 1500 miles until I had to take it off again for some other work.
Sean
1987 944 N/A primer white. Will be painted... eventually...
Mods: only944 shift leaver, only944 short shifter, lindsey racing vacuum lines, koni struts, kyb shocks (for now), red springs and calipers (Everyone knows that paint adds 15 HP)
Old 01-20-2015, 07:06 PM
Mountain Road Maniac
ColoradoSteve's Avatar
I've done three belts on my car using the 'twist' method and never had any problems. You also tell by the sound; if it whines, it's too tight; if it flops it's too loose.
'83 944
'87 951- SOLD!
Old 01-24-2015, 03:56 PM
