Porsche Crest 83 cloud of smoke help!
Hello guys
I recent got my 83' automatic 944 running after a another 944 engine swap, problem is when I run the car a cloud of white smoke comes out of the auto shifter, what could cause this? And how can I fix it? If I were to guess it is a transmission or power steering line that is leaking onto the cat if I were to guess, any ideas?
Old 01-22-2015, 03:11 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
white smoke
Is the smoke in the engine bay as well? If it is, then I'd suggest cooling the engine off and getting under the car and looking for wet spots around the power steering hoses below the engine and from the reservoir to the pump. Is the fluid dripping on the exhaust manifold, pipes or collector? Are your brakes and fluid ok?
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 01-22-2015, 03:22 PM
FLYGEEZER's Avatar
What kinda smoke? Whats it smellin' like ?
Edgar
1984 Porsche 944 bone stock
1995 Mercedes E320 wagon
1970 Honda CB350 mint!!!
Old 01-22-2015, 03:33 PM
Oh no it's not from the engine and there is no leaking anything from anywhere the smoke only comes from the interior making me think the leak is a line of something above the cat
Old 01-22-2015, 03:35 PM
ATF smokes like crazy
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 01-22-2015, 04:52 PM
9FF 9FF is offline
9FF's Avatar
Are you loosing coolant? A failing heater hose at the rear of the engine will drip coolant in and around the bell housing and it turns to white smoke when it hits the exhaust. It's possible the smoke is getting into the car through the shifter. Worth checking first as it's an easy fix. Telltale sign is the smoke will smell "sweet".
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 01-22-2015, 05:29 PM
FLYGEEZER's Avatar
An automatic with a flex disc is even more important to get it fixed & cleaned up pronto if it is a coolant leak or a transmission ATF cooler line to/from radiator . The center on the disc gotta stay dry as those kinda fluids will "eat away" at the rubber & it will fail. Now ya gotta lot of work to do.
Edgar
Old 01-24-2015, 01:41 PM
