Rob 924s's Avatar
Porsche Crest 924s help appreciated-coolant in the oil
Hi guys, I'm new here so hopefully this works out. I'm 17 years old and this past summer I picked up a 1987 Porsche 924s that had been sitting for about maybe 12 years. It was free from a family friend, but not close to running. Now after fixing numerous electrical problems, and replacing the head gasket, I am still getting water/coolant in the oil making the oil very frothy. Could this be happening in the oil cooler? or are there some common issues with this? I'm just hoping its not a cracked block.
Old 01-22-2015, 04:07 PM
9FF 9FF is offline
9FF's Avatar
Coolant in oil is almost always the oil cooler seals. Cheap to replace but a pia to do and you should change the rod bearings and flush the engine at the same time.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 01-22-2015, 04:22 PM
Rob 924s's Avatar
Thank you very much. I just watched this video I found elsewhere on the forum, https://www.youtube.com/watch?v=5yoiZIDFtEY, and now I'm just wondering, would I need that special tool to align the holes for the oil pressure relief valve? Or is it possible to
Old 01-22-2015, 05:00 PM
Toofah King Bad
Rasta Monsta's Avatar
Best practice at this point would be to pull the engine, inspect the clutch, change the bearings and do a reseal.
Not a small task, but worth it in the long run.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-22-2015, 06:39 PM
Tags
924s , 924s engine , 944 , 944 engine , coolant leakage
