-   -   Speed and reference sensors (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/848025-speed-reference-sensors.html)
Cocacolakidd 01-22-2015 09:48 PM
Hello gang,
I ran into a quirky problem when working on my 85.5 944 - On the mount block that mounts the speed and reference sensors is a third sensor to the outside of the other two - I can find no reference to this third sensor in the manual or any place else.
Pfunny time to run into something unknown as I have the mount block and other sensors pulled out - even have a washer filed down to .8mm and glued to old sensor for clearance purposes when re-mounting.
What is this third sensor - what is it for - are their any clearance or mounting instructions for it?????
TYVM in advance, Ed.
(Thank you very much)
Grandad#3 01-22-2015 10:20 PM
Hi Ed, the third large opening is for a factory diagnostic plug which is no longer used.
Cheers,
Larry
Cocacolakidd 01-22-2015 11:57 PM
Larry thanks so much - Couldn't hardly feel good about putting it back together with out knowing what that third sensor was for...
tyvm, Ed.
