1984 944 cabin heating problem
Hello all.
At an idle or slow driving with fan on high the heater blows cold air. If the blower is turned down one click it gets a bit warmer. On fan speed 1 it is hot. This happens no matter what the heater settings are on. This is with heat setting on hot.
At driving speed it gets a bit better with the blower is on high, but the revs need to be up.
Please help?
Old 02-05-2015, 09:54 AM
Proprietoristicly Refined
John_AZ's Avatar
It could be a bad heater control valve:
944 Foot To The Floor: How to repair heater control valve on a Porsche 944 (Square Dash Model)
It could be a simple duct heater clip:
944 Heater Fix
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 02-05-2015, 11:10 AM
Thank you. Does anyone know where I can get the heater control cable?
Old 02-05-2015, 11:15 AM
Bradical's Avatar
Naturally lower-velocity air spends longer in contact with the heater core and is therefor going to pick up more heat than higher velocity air will. If your heater control valve isn't open all the way you will have poor heating but the air will feel warmer the lower you run the fan.
Old 02-05-2015, 12:35 PM
nightheart's Avatar
The 84 doesn't have the heater duct clip, its all cable driven and not that great of a setup. Check the cable running to the heater control valve and make sure its not bound up, loose, etc. My guess is the heater control valve simply isn't open the whole way. There's a god awful 97 cent clip that holds the bowden cable to the heater control valve. If you can get your hands in there, unhook the clip and disconnect the cable from the control valve. Slide the leaver on the control valve all the way to hot and see if that improves the hot air on 3. You're still not going to get great heat on the max setting, sitting at idle, in freezing temperatures.
Good Luck
This was probably posted from my phone, so please excuse any typos.
Old 02-05-2015, 06:51 PM
Thank you for your help..
Old 02-06-2015, 07:26 AM
