Oil Pressure Relief Valves
After many hours of trying to figure out what oil pressure relief valve I have in the 924S I came across this tutorial which has (wait for it!!) PICTURES...
Some of you may find it helpful if you have to remove the oil cooler and need to order replacement o-rings and washers for the OPRV.
I was able to remove my oil cooler without removing the exh manifold but getting the four bolts started back in for reassembly will be a challenge. Not much room but if that German guy can do it, maybe I can......
944 Foot To The Floor: How to remove and replace OPRV (Oil Pressure Relief Valve) on a Porsche 944
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 02-07-2015, 08:43 AM
Not bad, the 8th picture down I originally posted to pelican. I hereby give up all copyright to this picture.
I recommend a flexible 1/4" extension on a nut driver to get the oil cooler housing bolts bolts back in.
Sears.com
Then you need to switch over to a swivel head 3/8" drive ratchet to tighten them down.
Sears.com
Old 02-07-2015, 12:08 PM
Send a message via Skype™ to massive
Glad you don't mind, it was for a worthy cause.
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 02-10-2015, 05:10 AM
Andrew Gawers' Dad
CHICKS's Avatar
Rennbay will be selling a late OPRV with tool soon for like $185, just something to get excited for.
Old 02-10-2015, 10:13 AM
Fortunately I have the other one-piece valve and the tool is only $20.00.
But my understanding is that the older valves of the style I have were not treated for corrosion and are prone to fail. I have no idea if my valve has that problem except that it was working fine. I'm just going to put it back in and not worry about it!
Jon
87 924S
82 924-Gone.
Old 02-10-2015, 01:07 PM
