Diving in 911
86 Turbo fan resistor wiring diagram...
Thought I would post this for any others that might have the 8-post resistor configuration that appears to be unique to the 1986 model year. If you go under the dash for anything CHECK IT. all that I went and looked at trying to figure mine out were burnt with exposed wire. Finally found a hull that I was able to cut the sample out of to get the harness-to-resistor wiring colors. Hope this helps somebody.....
1976 911s Special Edition Turbo bodied IROC tribute
2002 911 Carrera C4S
1971 914 1.7 Tangerine
1989 964 Coupe/1992 964 Cab
1987 928s4 Granite Green / 1986 951
Old 02-18-2015, 08:50 PM
