944 Mirror help?
I have posted a few times about an accident I had and repairing the damage. Last thing to be done is reparing the passenger side mirror. Does anyone know what the mirror is made of and ideas on how to repair it? The little metal tab that stops the torx screw from just going straight through the mirror has broken off. Im thinking of maybe trying to weld it or something? or is it made out Aluminium?
Old 02-19-2015, 02:26 PM
PA_944's Avatar
I think its some kind of alloy.
Probably best to pick up a used one on ebay.
Old 02-19-2015, 04:03 PM
Id really rather not based on the price and problem and the only one I could find in white is In pretty poor condition and the guy wants $90, maybe jd weld? I mean just stuff to try before spending anymore of my dwindling 17 year old money supply
Old 02-19-2015, 05:39 PM
PA_944's Avatar
Ok,
I doubt the JB weld will work but you can try it.
Other option would be to carefully drill out the existing hole to leave a collar and fit a washer with the original screw.
Either way you'll have to be careful tightening it as it will be weak.
Best of luck,
Old 02-19-2015, 06:58 PM
I talked to a Porsche mechanic.... who said.... literally... dramatic pause....
To superglue it...
Old 02-19-2015, 07:08 PM
yundar's Avatar
I would think JB Weld would be stronger than super glue. It won't hurt to try. They make some pretty strong epoxies these days.
I have a set of those mirrors for sale (in red) if you need them. They have the 928 part numbers which I see yours do too. The early 944s must use the 928 part numbered mirrors. I bought this set to replace a broken one on my 87. It wasn't until I received them that I realized the late 944 mirrors are slightly different and have a 944 part number.
The mirrors I bought have heated glass and as such the wiring harness is different. The base of the mirror is also a slightly different shape. Something to be aware of if you are buying used mirrors online like I did.
Old 02-20-2015, 08:44 AM
Tags
mirror , porsche
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
