VOTS89's Avatar
Connecting Rod Nuts/Plastigage
My engines out of the car and I'm changing the rod bearings.
Since we don't reuse the old rod nuts, do I check the bearing clearance with the old rod-nuts or the new rod-nuts?
Torquing the new nuts to spec and then removing them to inspect the plastigage seems odd.
Thanks...Bruce
1989 944 N/A
1995 Ford F150 4X4
2016 Infiniti QX-70
2016 BMW 1200GS
Old 02-21-2015, 06:56 PM
Use the old ones.
Old 02-21-2015, 07:36 PM
VOTS89's Avatar
1989 944 N/A
1995 Ford F150 4X4
2016 Infiniti QX-70
2016 BMW 1200GS
Old 02-22-2015, 07:11 AM
Right behind you on doing the connecting rod bearings.....a little preemptive at 93k but the kit was on sale))
Did you have the crank polished?
Old 02-22-2015, 07:24 AM
VOTS89's Avatar
I didn't have the crank polished or replace the main bearings and I don't know if I'll regret it later. The bores look sweet so I'm hoping I'll get lucky.
I know I'm so close to rebuilding the whole engine, I go back and forth in my head about taking the short block to the machine shop.
How about you?
Bruce
1989 944 N/A
1995 Ford F150 4X4
2016 Infiniti QX-70
2016 BMW 1200GS
Old 02-22-2015, 08:16 AM
Most ppl that I know with these cars get 250k out of the rings so better left untouched unless there is oil consumption.
The car had the upper balance shaft off a tooth when I purchased it and the hall sensor wires where shot from heat. Resealed the front and oil housing and I have replaced the mounts with some very cheap ones...$17 clearance item cheap so I bought 4. Car is very smooth after the pistons warm up a minute.
Hot oil pressure is good but not perfect and most professional mechanics on these motors notice cylinder wall issues if the con rod bearings are allowed to get too shabby. I like the Lindsey racing improvements to the oil pick up and my plan is to go this route.
Old 02-22-2015, 09:17 AM
Bradical's Avatar
Back up... The rod nuts need to be replaced because a service bulletin came out to order the replacement of the smooth-face nuts that the engines were shipped with with replacement ridge-faced nuts.
The nuts are not one-time use and they can be torqued and removed. They are not egged or oblong.
Old 02-22-2015, 09:32 AM
He is just temporarily using them to check clearance.
Old 02-22-2015, 09:53 AM
Bradical's Avatar
Yes that's fine, the point is that it doesn't matter which ones you use for the plastigauge.
Old 02-22-2015, 10:06 AM
Good catch though))
I am a doubting Thomas by nature and the number 2 rod bearing thing, I feel, is a combination of many things. Aerated oil or lack of oil at the pick up is probably the main offender but other things come to play in my mind. The force/inertia vectors in the balance weights are pretty close to same plane as number 2 on the crank. I am really to lazy to do the math on the primary or secondary harmonics but due to packaging, there has to be a compromise to lessen the first order and let the lessor vibrations fall where they may.
And why does the oil return dump next to the pick up? If you pour a Guinness stout, it takes a good ten minutes for the head to go down. There is no way to rephrase that...I feel like Leslie Neilsen and just farted before the camera rolled.
Old 02-22-2015, 10:10 AM
Bradical's Avatar
Here's the page I was talking about, just to further clarify. I was under the impression they were one-time use when I did mine, too.
Old 02-22-2015, 01:34 PM
VOTS89's Avatar
Thanks for the additional info, I'll be replacing the bearings this weekend.
Bruce
1989 944 N/A
1995 Ford F150 4X4
2016 Infiniti QX-70
2016 BMW 1200GS
Old 02-23-2015, 07:26 PM
