-   -   944 5-speed trans. problem (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/85421-944-5-speed-trans-problem.html)
Stanton Horne 10-26-2002 06:16 AM
Which shaft is the 2nd gear synch. ring on. Or what number is it on the drawing. 2nd and 4th are the same and I want to be sure I replace the correct one. Thanks
SoCal Driver 10-26-2002 09:10 AM
Do I take it you have a trans apart?
What drawing with numbers are you refering to?
Stanton Horne 10-27-2002 06:50 AM
I have the transmission apart. There are parts diagrams on the Pelican Parts Page. The parts diagram is on the left side after I click Pelican Parts and under 924/944/968 is a line for parts diagram.
SoCal Driver 10-27-2002 09:17 PM
OK. Back home from weekend retreat.
I'll scan and send both a diagram and the related parts referances.
