Fuel seep
I replaced the gasket for the fuel sender on my 924S and I still have gasoline seeping through the top of the sending unit, apparently through the terminals Has anyone one experienced this? I had gas leaking through the positive terminal of the fuel pump last summer, necessitating a replacement..twice, actually. It's fine as long as I remember to not fill it up.
Old 03-15-2015, 06:48 PM
Proprietoristicly Refined
John_AZ's Avatar
Yes, replace the fuel sending unit.
If you grab the male brass terminal and it moves the insulation has cracked. Fuel will leak out and could lead to a short on the grey metal top of the fuel sender or touch something else under the grey metal top. There is no fix as it is a factory pressed connector.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-15-2015, 09:04 PM
Gas tank repair epoxy?
A new sending unit would be the ideal repair ($133.75 at Pelican).
Most auto parts stores sell fuel tank repair epoxy which may work, if you are on the cheap and depending on the particulars of your leak. I have no experience with gas tank repair epoxy so use your best judgement if you try that. Whenever using such things surface prep (mostly cleaning) is important. Good luck.
1988 Silver 924-S Original owner
Porsche 924S: The 944's cheaper, faster little sister.
Old 03-17-2015, 07:50 PM
