Boost and vacuum issues...
I picked up an '86 951 today. It seems to idle a little rough and starts off a little rough until it gets to about 2000rpms then it runs like a really solid n/a. It doesn't seem to have any boost at any rpms. The PO replaced head, the fuel pressure regulator, vacuum lines, and cycling valve, to no avail. The good news is, I have another turbo that runs great to use parts from to diagnose. Any ideas on where to start?
Thanks!
'87 951 Nile Green, '86 951 Black, '86 951 Sapphire Metallic, '87 944 Nautit Blue, '84 944 Black (sunroof delete) "Track Beast!," '87 944 Black (LSD, Konis) (wife's track car) |
Do you have an air compressor or access to one? A boost leak tester is easy to make and can be a huge help in these situations. That is where I would start.
-Brad 2002 Carrera2 1986 944 Turbo |
Good idea!
Anyone else?
Toofah King Bad
Drive it around and check the pipe between the wastegate and the cat. If it's hot, WG is stuck open = no boost.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
winter-hater club member
also, make yourself the led KLR blink code dealio. that will tell you if it is in limp mode and, perhaps, why.
also, a large vacuum leak can turn into a large boost leak. i'd look for splits or other issues on the high pressure side of the intake system, from the turbo to the cylinder head.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever Last edited by nynor; 03-27-2015 at 03:03 PM.. |
I pulled the wastegate open- no valve in it...at all. Probably why it wouldn't boost!
Well that is concerning!
don't you just love all the little surprises on these projects.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
Toofah King Bad
Hopefully you mean by this you found it on the side of the road and picked it up. Because. . .
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc Last edited by Rasta Monsta; 03-29-2015 at 07:53 AM.. |
well, that is one way to prevent over-boost....
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
this begs the question: where did it go? is it possible for the exhaust system to swallow it?
I literally found it- in the exhaust pipe behind the wastegate, the pipe that runs along the cat converter.
at least the turbo didn't eat it.
If his turbo sucked a valve back UP the exhaust, there'd probably more going on than just a busted turbo.
FYI, the turbocharger is downstream from the wastegate, where the valve is missing.
Perhaps I have it backwards in my head, but if the valve face broke off, wouldn't it fall into the post-turbo side of the exhaust, much like a manhole cover can't fall INTO the sewer?
i believe you are correct. i misunderstood where you were going with your previous post. my bad.
944 addict
Don't scare me with stuff like that. I'm still working on my newly acquired 951 and I this turbo stuff fogs my mind sometimes.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
WOW! It's amazing how much better a car can run when all of the pieces are back in order! Looks like I made a good deal on this turbo.
