Wardog's Avatar
URGENT!! Need technical info about porsche 944 parts
I`m restoring a 1986 porsche 944 NA with some parts of a 1986 porsche 944 turbo (burned), and I need to know a few things with extrem urgency...
-Does the FRONT wheel bearings fits in the REAR wheel???
-Wich are the measures for the conic air filter arm???
-does the co-pilot seat works to be fit into the Pilot side??
-does the front bumper from the turbo fits into the NA??
-Besides of the original enginethat comes with the porsche 944 NA, wich other engine can be installed?? one that doesn`t need to replace any other part of the car....???
I hope some one can help me in this little mess I`m stuck in....
Step on it!!!!
Old 10-30-2002, 11:21 AM
Wheel bearings front and back have different part numbers.
The seats are interchangable left to right but it puts the fold down lever on the inside making it diffisult to operate.
The turbo front valence will not fit on the NA fenders without some cutting and fitting. There is a different angle at the front of the fender.
Can't help you with the air cleaner horn; Don't understand the question
As far as I know, there are no direct replaements for the engine, although there is a kit that will permit the installation of a Chevrolet V8. However, this requires additional changes including a different radiator to insure proper cooling.
Hope this helps.
Bob S. former owner of a 1984 silver 944
Old 10-30-2002, 11:39 AM
