Brake Malfunction
Perhaps my search skills are fading because I couldn't find what I needed here and I know the answer is here somewhere. I'm experiencing what feels like brake fade. No matter how hard I press, there seems to be no resultant increase in braking force. Master cyl is about 20 years old. Pads and rotors are brand new hawk/Zimmerman set up. Everything else is circa '86.
Found some where here that if the pedal doesn't move at all during start up, then the booster is perhaps faulty. Should I replace the $22 check valve for starters? Also noticed this sweating...
86 951 blk |
Custom User Title
It could also be a vacuum problem.
I went through all that on my 951. I just wasn't getting any assist, so I figured the booster was bad. I went through the whole trip of replacing the booster - which is kinda a pain in the ass. I got the new booster in and there still wasn't any assist. Upon further investigation, I found the venturi had been leaking, so I did a delete (rerouted the vacuum lines to do away with the venturis) so the vacuum for the booster was coming direct off the middle outlet of the intake. Then the brakes worked perfectly. I'm not sure why they used the venturis - The ***** is that when the venturis get old, they leak. So you might wanna check your vacuum lines.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
86 951 blk |
If you look carefully the venturi is a two piece design with an o-ring where the pieces join. New one is not very much. Don't know about rebuilding it.
Custom User Title
Here you go: VACUUM DIAGRAMS at LINDSEY RACING - Your Porsche Performance Parts Center
Yeah, it's necessary to take the intake off to do the venturi delete. To check to see if that's it, you could simply take off the current brake booster hose, plug it, then run a new hose direct to the middle vacuum port on the manifold. You'd also have to plug the end of the existing hose (so there are no vacuum leaks). Then with the vacuum jumper in place, see if it makes a difference. That'd tell you if it was worth it to pull the manifold. Mine it was like night and day.
86 951 blk |
Alright... did the venturi delete thing. If for nothing else, things got a bit tidier and much better looking under the hood - me likes. But alas it did not address my problem. The brake pedal does drop a bit on start up. So I am assuming that I am getting some brake assist. Any tips on checking brake master and booster?
86 951 blk Last edited by JAXTURBO; 04-25-2015 at 03:27 PM.. Reason: crappy english! |
Toofah King Bad
Can you smoke test the booster? Did you check the function of the check valve?
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
86 951 blk Last edited by JAXTURBO; 04-26-2015 at 03:47 PM.. Reason: readability |
I was just curious, did you try the start up test that you mention in your first post?
Pump the brake pedal, hold it, then start the car. If the brake pedal doesn't move then there is a booster problem (or vacuum problem). If it does move down some, then the booster is probably ok.
'90 944S2 cab - sold after 20 years, will not be forgotten. '04 Mercedes SL500 - Nice but my S2 was more fun to drive. |
86 951 blk |
Brake fluid looked real nasty. It was very dark. I mean dark. So I flushed/bled. Noticed a creaking sound coming from the left front. Wondering if I need to rebuild that caliper? Interesting thing is that the car doesn't pull to one side or the other, so I don't think that creaking sound was a hanging caliper piston. Rebuild?
86 951 blk |
