LinkBack | Thread Tools | Rate Thread |
More Boost!
Why are my balance shafts misaligned after setting them correctly?
Motor was set at TDC before installing belt, I verified it via bellhousing and camshaft notch. Top/Bottom balance shafts lined up perfectly at each respective notch before starting also.
I installed the balance shaft belt, lined up everything tighten the belt to 180 degree turn with fingers, started the car, let it run for 1-2 minutes, put motor at TDC again, rechecked belts and the top balance shaft is aligned with notch, bottom is off by 1.5 teeth...why?? YouTube Video Below: https://youtu.be/fAnUYVqZE5s Last edited by fiily; 04-10-2015 at 04:54 PM.. |
Scroll down to the second post and give that a try. I hope it helps!
924Board.org :: View topic - How to set the timing and balance shaft belts on a 924S/944
1986 944 -Garnett w/Koni suspension 1987 924S -Red, 951 Swapped, ~300hp 1987 924S -Red, project car 1987 924S -White, Project car 1988 924S- Red, Bone stock, Daily driver |
Toofah King Bad
Because you didn't set them correctly?
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
It's common, as you tighten the belt will stretch a bit. What looks like dead on with a floppy belt can be a few teeth off under proper tension. Correct and move on. There is no greater force at play here.
More Boost!
Do you think I had slack in the belt and that is why this happened? |
More Boost!
Toofah King Bad
More Boost!
Ya! Too much. A beating and flogging would be better.
Either way, I redid the Balance belt again yesterday afternoon, and the same freaking results!!!!!!!!!!!! ![]() I must have slack on the belt which jumps teeth on the lower balance shaft sprokcket, causing it to get off time with the engine. Gonna grab the wife/kids to hold the top balance belt sprocket while I run the belt down the crank, lower bs and tensioner to prevent this. We'll see, if it doesn't work, I will be offloading some ammo into the block.
winter-hater club member
do you have a contitech balance shaft belt?
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
More Boost!
Yes, I bought the contitech timing belt kit which includes both belts, rollers, tensioners. Please tell me you figured out my problem nynor.
CRP Industries TB107-293K2 Timing Belt Kit For sheets and giggles, I ran the car for 25minutes without the balance belt, ran smooth as butter. I had the car up on jacks about 35deg, and thought I needed to bleed the system, but my stant pressure tester worked by bleeding the coolant system, the car stayed at the 1st white line and the cooling fans came on. I had the fan on 0 and the heat cranked to hades hot. This balance belt malarkey is the only thing stopping me from finally driving the car since last summer!! HELP!!! Last edited by fiily; 04-12-2015 at 03:57 PM.. |
If you install the belt with the marks lined up, the slack when tensioned will pull them out of alignment. This isn't any different than doing a twin cam car with two cam gears. The sprockets need to be retarded before the belt is put on, then aligned.
well, let's just say i had the exact same issue using a conti balance shaft belt. if you look at the teeth, they have a cutout. if you look at the teeth with the belt around one of the balance shaft pulleys, you'll also see that there is some slop. after four goes, i decided i just didn't trust the belt and bought a gates. i had forgotten that i had a conti in there. low and behold the teeth on the gates are round and fit the pulley like a glove. problem solved.
if you do a search of my recent posts on this forum, you'll see where i discuss my problem a little bit. then i looked on the wall in my garage, where i lovingly place all the belts i change on hooks for later use as rubber protectors for vice grips and such. low and behold there were two or three balance shaft belts still hanging there. all of them with round teeth. one more thing, i had also purchased and installed the entire kit. so i am not sure if the belt sold separately is different.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever Last edited by nynor; 04-12-2015 at 04:39 PM.. |
More Boost!
Started the car, let it run again for 2-3 minutes, put the engine to TDC, verified TDC via bellhousing and cam again, and the top balance shaft was right on the notch, the bottom was off by 1.5 teeth. So, with everyhting tensioned, and lined up, everything should "stay" lined up at tdc, but obviously it's not happening. Last edited by fiily; 04-13-2015 at 07:28 AM.. |
with the conti belt, i actually over tensioned it a bit, the fourth go, and it still jumped teeth. except i actually ran my car, between tensionings, on the road and it was going 180 degrees out of phase. good luck.
In the link, I described how to move the slack to the tensioner. If all the slack is not at the tensioner then the belt will pull the shaft out of time when you start the car. The way I described is how service techs do belts on all cars to get the marks to line up with the belt on. They don't have time to spend days doing a job or replace a head when they get the marks wrong.
More Boost!
Thanks Ed. |
first off, he wouldn't have smashed valves, as we are talking the balance shafts. second, if he followed the instructions on clarks, he would have rotated the engine twice back to TDC and it would have taken the slack out for a second reading.
again, the conti belt sucks. YMMV.
Nynor, this is the same principle tech use to install belts on all cars. I'm being rhetorical, but if he was working a twin cam car he would have this same exact issue which would result in smashed cams.
More Boost!
I have turned the engine over by the crank after setting the belt tension, and retensioned then and still it happened, we will see if the way ed mentioned in the thread resolves it. |
your belt is exactly as i described. there is a notch at the end of each tooth and the teeth are more triangular than round. i am done here. good luck.
