Kokes
Safetied and on the road. The adventure begins
So, I was able to get my 944 project on the road and legal here in Canada. After taking it out for a nice hard drive I'm getting ready to work on the vacuum lines and change out the old grounds and primary wires.
My question to you, my fellow 944 brothers and sisters, is it necessary to use all the elbows and tubing that was used originally or can I use generic vac tubing? Also, is there any advantage to using heavier gauge (2 or 0) for ground and primary cables?
I can tell you that she runs through the gears beautifully and is everything I thought she would be. It is hard to believe that this car is 31 years old.
Old 05-15-2015, 07:22 PM
Proprietoristicly Refined
John_AZ's Avatar
Depends.
A few sellers offer vac kits you could copy and DIY.
An example:
VACUUM & FITTINGS at LINDSEY RACING - Your Porsche Performance Parts Center
Battery cables- some swear it helps:
IceShark is AMAZING!!!!!!!!!!!!!!!!!!!!!!!!! - Rennlist Discussion Forums
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 05-15-2015, 09:15 PM
Kokes
Thanks for the info J_AZ. I will let you know how it goes.
Old 05-16-2015, 03:34 PM
M. Murphy's Avatar
I have the Lindsey Racing silicone set and it includes metal fittings. The silicone should handle underhood heat better than the original. Been on my 83na for two years no problems.
Old 05-17-2015, 04:34 AM
Toofah King Bad
Rasta Monsta's Avatar
FWIW, the contents of the LR set can be had cheaper if you get bulk line and nickel plated fittings from McMaster Carr.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 05-17-2015, 08:50 AM
Kokes
Okay I was finally able to change the primary cables and grounds on my baby.
She started up right away. But, the battery light is on. I have checked the voltage atbthe battery and it sits around 12.46.
Can someone help me out? The cable from the battery to thee starter is 0 gauge. The following what was there I used 4 gauge from the starter to the alt. The blue wire from the alt to the connector was completely fried I noticed that the previous owner or mechanic had jumped that wire completely instead of fixing it so I did.
The grounds are 0gauge as well from battery to chassis and chassis to bellhousing. That was not fun at all to work on.
Let me know if any of you see a problem with what I have done.
Old 05-30-2015, 04:37 PM
