Michigan944
Porsche Crest Clutch Going Out?????
I noticed driving my 944 today that the clutch was feeling lighter than normal and whenever I went to shift it was noticeably notchy. I replaced the slave cylinder last year and it appears to still be in working condition. I haven't noticed any loss of fluid from the reservoir. Is it the clutch??? I was also thinking the master cylinder, but I haven't noticed any loss in fluid. Any ideas???
Old 05-12-2015, 04:18 PM
PA_944's Avatar
Master cylinders can fail by leaking the fluid past the seals under pressure. This will not result in a leak.
Old 05-12-2015, 04:22 PM
Bradical's Avatar
How are you with a set of wrenches? I'd say replace the blue hose, high pressure line and master cylinder (would have done all that when I did the slave, but that's just me). If you still have issues those should be replaced during a clutch job anyway, so no loss!
Old 05-13-2015, 12:06 PM
