transaxle oil
Is there a way to add oil to the transaxle without going through the filler plug?
Dimi Paralanov Flying Horse Motorsport flyinghorsemotorsport@gmail.com |
What’s the question behind the question?
John |
can't get the plug out. Changed the shaft seals and some fluid came out.
1) Buy a new plug.
2) Weld a 17 mm bolt into the old plug. The heat of welding will loosen the plug. Remove the plug. 3) Add oil. 4) Install new plug. Tighten to 17 ft lbs.
Good luck, George Beuselinck |
Thanks for the tip. I will give it a try.
