Flywheel Pin Orientation - Why? And Which Pin?
Got the old RMS out and the new one installed, and the flywheel is back on.
Haynes and Clarks mention that the pin on the flywheel must be pointing straight down prior to installing the clutch disc and pressure plate.
Well, there are three pins on the flywheel - two fairly close together near the front of the circumference, and one near the back of the circumference.
Which flywheel pin do I use? And once the correct pin faces down - is there a "proper" axial orientation for the disc and pressure plate to go back on relative to this pin? I'll be using the alignment tool - but it looks like this is just for making sure things are centered and the splines line up - and not for general axial orientation.
My engine is out of the car - and maybe the deal with the flywheel pin facing down only applies to engines that are still installed...to ensure TDC?
So I'm scratching my head on this. Any Sage Advice? Thanks!
Old 09-23-2010, 11:46 AM
....when i had mine out, i think there was only one way it'd go back in and have all the flywheel holes still line up.
Old 09-23-2010, 11:51 AM
I didn't think to look to see if the p.p. only goes onto the flywheel one way when I removed it, nor did I think to make my own orientation marks. So, Krystar, I hope you're right! Will tackle this tomorrow.
Old 09-23-2010, 01:00 PM
Proprietoristicly Refined
John_AZ's Avatar
The 3 FW pins are in the down- bottom of flywheel, position, so that when you install the bell housing, the Sensor bracket and sensors you do not damage the pins or the sensors.
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 09-23-2010, 02:54 PM
I was wondering the same thing, about whether there is a fixed pressure plate angular orientation required?
2002 C4S 105kmiles
Boston MA
Old 05-17-2015, 02:34 PM
