87 944 S Brake Upgrade
As some of you may already know I have a 944 S, and I am having my engine rebuilt at N-Tech Motorsports in Winter Haven, Florida. I decided to increase the final hp a little bit over factory numbers, however I was thinking about stopping the car . I need front and rear calipers for the car as I do not have any right now (parts car turned back into daily driver). I do not want to swap out for the turbo spindles and what not (seems like too much). Is there any KITS or calipers with adapters I can buy directly from the manufacture like Brembo or Wilwood that will fit the current late 944 S setup?
Old 02-21-2015, 04:14 PM
Toofah King Bad
Rasta Monsta's Avatar
Why swap spindles? Didn't that car come originally with four pot Brembos?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 02-21-2015, 04:25 PM
Don't think so, Car never had any front calipers at all when I picked it up and it looks like it has regular late NA rear calipers.
Old 02-21-2015, 04:49 PM
Porsche 944 Big Brake Kit - NA
bolt on.
944S has the same brakes/suspension as regular 8-valve NA.
Old 02-21-2015, 07:41 PM
Toofah King Bad
Well, FWIW the factory pieces are excellent (I and many others race on them) and dirt cheap. . .it's really all about pad selection.
Your money might be better spent on freshening the suspension, which would give more bang for the buck in overall driving experience.
Old 02-21-2015, 09:51 PM
It seems like I might have to buy a big brake kit for the front because no one sells the complete (rebuilt) calipers for the front anymore. I can get the rears for a reasonable price almost anywhere but the fronts seem all most impossible to acquire. What gives? any other suggestions.
Old 02-22-2015, 04:05 AM
not sure if there's a piston size difference but im 99% sure the rears are identical to the fronts?
see this..if you provide the mounting hardware this might be too cheap to pass up.
http://www.oreillyauto.com/site/c/detail/OBH3/19724/03345.oap?year=1984&make=Porsche&model=944&vi=1263541&ck=Search_brake+caliper_1263541_2666&keyword=brake+caliper
Old 02-22-2015, 06:31 AM
So, I could buy new or used rear calipers and put them on the front?
Old 02-22-2015, 12:24 PM
BrakeBest 19-724 - Brake Caliper | O'Reilly Auto Parts
I need the complete caliper not just the piston housing part.
Old 02-22-2015, 12:25 PM
check lart's porsche parts on ebay, or plyhammer/gravesjeg/kens911/dimi944 here on pelican, somebody's got to have na calipers laying around.
Old 02-22-2015, 03:53 PM
Toofah King Bad
Call 944 Ecology or PartsHeaven. . .I would guess either will send you cores for next to nothing.
Also carparts.com is a pretty good junkyard source.
P.S. No, front and rear are NOT interchangable. . .hilarious!
Old 02-22-2015, 04:03 PM
kevingross's Avatar
I put the calipers from an 87 951 on my 87 944S many years ago, and they made a marked difference at the track. You do need to swap the spindles as well. Bump on 944 Ecology, George is the man.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 02-22-2015, 04:24 PM
dp951's Avatar
944 turbo brakes
It easier and less expensive to swap out spindles and rotors than most of the brake kits out there , make sure you add the bias valve if not already equipped . get that from a turbo also . ( less than 2 hours )
Old 02-22-2015, 05:02 PM
Toofah King Bad
Originally Posted by dp951 View Post
It. . .less expensive
Until rebuild time, of course.
Old 02-22-2015, 05:57 PM
Originally Posted by Rasta Monsta View Post
Call ...PartsHeaven
you trying to bankrupt the guy?
PH should be the last, last, there are no-other-of-this-part-left-in-the-world resort.
PH is like those auto-title loan companies, because that's what their prices amount to.
Old 02-22-2015, 06:19 PM
dp951's Avatar
944 brake upgrade
There's no better fit than oem parts , the 944 turbo calipers are work horses and are every where moderately priced , and the reliability is second to none . Monies well spent
I owned and rebuilt many 944 turbos as well as the s2 and 968s ( over 20 years worth ). and the Brembos are built to last.
The ATE's are another story.
It easier and less expensive to swap out spindles and rotors than most of the brake kits out there , make sure you add the bias valve . get that from a turbo also . ( less than 2 hours )
Old 02-23-2015, 06:57 AM
So does the turbo rear calipers fit the 87 "S" 944?
Old 02-23-2015, 10:10 AM
dp951's Avatar
944 brake upgrade
Yes the rears are bolt on of course you be changing all 4 rotors and you need the 4 oem spacer washers .
Old 02-23-2015, 11:00 AM
Do you have turbo rotors or modified NA rotors?
Old 02-23-2015, 08:08 PM
That Guy
Techno Duck's Avatar
Generic 1/2 inch washers work in place of the OEM spacers.
If your looking to upgrade, i would just go with the factory Brembo's. Swapping the spindles is fairly easy also, just requires an alignment afterwards.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 02-23-2015, 08:14 PM
