-   -   DME jump works! non jump doesn't (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/865549-dme-jump-works-non-jump-doesnt.html)
Paulsporsche 05-16-2015 10:10 AM
Hey guy,
My 83 na auro 944 is having some electrical problems okay so here's the deal,
The engine is having problems with the fuel pump so when I run a regular DME the engine starts but doesn't run very well under gas and over gas, so I ordered a new DME. When I got the new DME and tryed to run it the exact same thing happend ! So I read online about the whole if you jump the pins the fuel pump will always run so I did that and the car runs almost perfect. Any ideas how I can fix this?
mattdavis11 05-16-2015 11:51 AM
A new fuel pump (DME) relay is what you want. Right here
1983 Porsche 944 Base Coupe - Switches, Motors, Relays, Fuses & Wiring - Page 4
I guess your relay is not dead, but has enough voltage drop to affect the delivery of fuel.
M. Murphy 05-17-2015 04:44 AM
Would a bad fuel pump DME relay cause a no idle condition?
