jezza944's Avatar
Steering column bush/bearing?
My steering column has quite a bit of play, like up and down, which is annoying on rough roads or corrugations. Is there a replaceable bush on the column near the top, just below the spline, or any adjustment to take this slack out? Any assistance appreciated. I did a search and can't find much on steering, apart from removing the whole thing.
Dave Jezza
http://www.pelicanparts.com/gallery/jezza944
1984 944na Krystalgrun (Crystal Green)
Old 09-26-2006, 08:13 PM
Back from Beyond
Yup. I think you can get the part from Automotion but it doesn't have a 944 part number. It's for a 914 (IIRC). Sorry can't think of it off the top of my noggin. The part is just a small metal sleeve. It's an easy install, but don't try to smash it in from the steering wheel side. Pull the wheel, take out the switch carrier and tap it in from the back. You'll see what I mean when you get it all apart. There's a nylon bush there that falls apart with age. Easy fix for annoying problem. Also, make sure you've got the large black steering wheel spacer/sleeve installed.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 09-26-2006, 10:39 PM
jezza944's Avatar
Thanks Simon, I'll pull it apart and if I can't get the part, I'll measure it up and get a mate of mine to turn one out on his lathe or make one myself from some scrap polly or brass. Its what I had in mind, but wasn't quite sure. I have a momo wheel in the baby, but the problem was there before I fitted that. Thanks again.
Dave Jezza
Old 09-27-2006, 04:58 AM
Back from Beyond
Anytime. Well, anytime I have half a clue...
All others GONE!
Old 09-27-2006, 05:04 PM
Did you end up making one or buying th e part?
Sent from my SM-G955U using Tapatalk
Bob Ward
80 931 powered by turbo Buick V6
Old 05-27-2017, 05:29 PM
