Question How do you lower the rear of the car?
I'm not worried about any handleing changes, and no, I'm not trying to make this 'step one' in ricing out my 944, I'm just tired of pulling into my driveway, opening the garage and being mooned by my 944's and 924's rear ends. I've heard it's a pain to lower the rears of these cars..is this true? Has anyone got any helpfull hints?
Thanks!
1985.5 Eurospec 944
1986 - 944
1997 - Mazda Miata
2002 VW Jetta GLS 1.8T
Old 11-07-2002, 05:43 AM
You can lower the rear about 1/2 to 1 inch fairly easily...there are several articles on the web that show you how. On the trailing arm, there are two large bolts, one of which is eccentric, which when turned will raise/lower the trailing arm. This part is easy to do.
Any height adjustments beyond this will require re-indexing the torsion bars, which is a BIG job.
Good luck.
Old 11-07-2002, 05:55 AM
Send a message via AIM to gforces944
JR.
I've also wondered about this topic as well, and I have one question. The rear has the special "Weissach" axle. I'm not sure how it exactly works, but I do know that it causes camber to change when the suspension is under load. This is what aids in the 944's spectacular handling.
Would adjusting this trailing arm to lower the rear end have any undesireable side effects on the suspension?
Rich
'86 944
221k miles and still kicks ass!!!
An Air Force Fighter Pilot was asked, "What's it like flying the F-16?"
He replied, "It's like driving a Porsche!"
Old 11-07-2002, 12:55 PM
Well, I'm no expert, (I can't even spell "Weissach") but if you lower the rear using the trailing arm adjustment, you will get a little negative camber...which could be a good thing.
I recetly installed 30mm torsion bars on my '83, and re-indexed them to lower the car to the max...(it's a stripped down race car now, and about 5 1/2 inches off the ground all the way around).
Afterwards, I had the car aligned, front and back, we used some figures from other 944 racers to set it up.
Toe is set to zero front and back.
Camber is -2.2 front and -2.5 back.
These camber settings would be a little to radical for street applications, but you can see that 944 racer's use a lot of negative camber in the rear.
...so a little negative from lowering using the trailing arm adjustment probably won't hurt. Just watch the tire wear.
Good Luck
Old 11-07-2002, 02:10 PM
Thanks,
That's good to know. What would be your suggestion to someone doing this at their local Porsche shop? Could the rear be re-aligned to a point to compensate for the change in camber?
I have a slight negative camber in my rears (-1.3) and there isn't a detectable difference in wear on my tires. I would like to keep it that way, should I decide to lower the rear this way (I don't think the SF region SCCA rules specify this as a modification to the suspension, so it might turn out to be in my favor).
Rich
'86 944
Old 11-07-2002, 03:22 PM
Makis's Avatar
You can adjust the camber at the front and at the rear on 944. So you can always adjust it to -1.3 if you want. And yes when the car is lowered the camber becomes more negative at the back but also at the front.
Old 11-07-2002, 04:11 PM
