28 Pin Conversion?
Who does the DME conversions from 24 pin to 28 pin?
I have a DME out of an 87/NA with the 24 pin stock chip, and have a used 944MAX chip that is 28 pin.
Thanks...
Old 06-02-2015, 07:18 AM
Banned
you can do it yourself. somewhere i have a pdf of the process, but if you are even reasonably handy with an iron you can do it.
Old 06-02-2015, 08:00 AM
Rogue_Ant did mine.
Old 06-02-2015, 08:33 AM
Thanks for the quick responses.....
Old 06-02-2015, 10:15 AM
In the Fires of Hell.....
kdjones2000's Avatar
86 to 88 Conversion ML3.1
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 06-02-2015, 10:48 AM
I've done a few. If you need any help let me know. I'm also willing to this conversion rather cheap if there's any interest.
1986 944 -Garnett w/Koni suspension
1987 924S -Red, 951 Swapped, ~300hp
1987 924S -Red, project car
1987 924S -White, Project car
1988 924S- Red, Bone stock, Daily driver
Old 06-02-2015, 12:13 PM
More Boost!
MAXhpkit Porsche Performance Products
Click services, $75 for 24-to-28 pin conversion, that's price includes shipping back to you, you pay shipping to russ.
Old 06-03-2015, 06:10 PM
Takes 5-minutes to do. Instead of the soldered jumper, i install header pins. Then use a jumper connector like for motherboards. Easily reversible mod for troubleshooting.
Old 06-03-2015, 08:01 PM
