Dashboard backdate
Hi, I have been looking for a good 924 turbo for a Carrera Gts build and have not been able to find a good candidate so far. The idea of a backdate on a 944 turbo is slowly growing. At the end it probably wouldn't be a lot more expensive.
I love to vintage look of the 924 dashboard vs the 944. As anyone tried to adapt an early s1/924 dash on a 944? |
the 1982-1985 944 had the same dashboard as the 924.
because of the AC system differences it'd be easier to put the turbo stuff into the 82-85 944 ![]() unless you're not using the AC/heater in which case the dash will fit just fine in a 951. |
Toofah King Bad
Why not use a 924S and swap in a 951 driveline?
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
a 951 conversion to a 924 Carrera GT has been done before. A Norwegian man built one for his wife. it was a yellow 951 and there was a sideshow of the build on youtube (which I can't find).
I don't think he backdated the dash.
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
plays with toy cars
I have a late dash for sale if you need one to cannibalize, otherwise you'll need to find a way to create and match up a good portion of the mounting points. On the early dash they are pretty straightforward. The hardest part is getting the HVAC I think, unless you're deleting the center console.
1983 944 - modded everything http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317 '86 951 - under construction http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374 |
