Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
coupe's Avatar
951 versus 944 tie rods..How diferent?
Hello... I think that I have just been supplied with 944 standard tie rods. How diferent are they from the 951's?
Will they hold, if fitted?
Coupe
coupe
http://www.p-caronline.com/directory/coupe
Porsche 944 Turbo, 1986
Fiat Coupe 20v Turbo, 1997
Old 11-09-2002, 08:42 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
SoCal Driver's Avatar
From what I've found there are three tie rod versions. The early non-power steering type, the power steering type and a variation on the power steering type that has a rubber dampener just outboard the inside joint.
Also there is an adapter that is required to fit one type to another.
I'll have to look into it. Do you have the part numbers for the one's you received?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-09-2002, 09:26 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
coupe's Avatar
Hi there...Please look at the pictures below.
Let me know what you think.. I will have the answear by monday from Zims, but still...I'm curious
coupe
coupe
Old 11-10-2002, 04:55 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
coupe's Avatar
OOPS! Here it is...
Here are the pics.
coupe
coupe
Old 11-10-2002, 04:57 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
coupe's Avatar
Picture 2, part number
Here is the part Number.
coupe
coupe
Old 11-10-2002, 04:59 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Here's what a Porshe parts book I have says about tie rod assemblies:
The main number is the same for all three.
944 347 033 XX
The end suffix changes for the three types:
01 : 83 till VIN 924 802 0051 also use stop ring 477 419 827
20 : 1983 - 1986 944 and 951(turbo)
20 : 924S
23 : 1987 - 1988 944S and 951 (turbo)
As you can see the VIN is for a 924 and should not apply to you.
Did you get the boots to go with the tie rods?
Old 11-10-2002, 09:30 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
coupe's Avatar
Hello there. Thanks for that info. Looks like I was supplied with the correct tie rods for my 951, year model 1986.
The boots I have already, they were fitted with the rebuilt power steering rack a couple of weeks ago.
Thanks again
coupe
coupe
Old 11-10-2002, 06:24 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Junior Member
does anyone know if the 930 Turbo Tie Rod PN 930 347 031 01 fits the 951S??
Old 10-22-2004, 08:41 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Mein Gott!
Panzer909's Avatar
No - they do not.
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 10-23-2004, 07:10 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Junior Member
perfect - thanks Panzer 909
Old 10-23-2004, 07:49 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
