Ben Selby
At what rpm do you shift from 1st to 2nd?
I drive a 1987 924s every day and I have noticed that no matter how and when I shift to second it's hard to let out the clutch smoothly. I have also noticed it in every 944 and 924 video on the Internet I have seen. I was just wondering at what rpm other people using these as daily drivers shift at.
try not pushing down so far on the pedal. going from first to second i generally only move the pedal about an inch.
its more a timing thing between your foot movements than an rpm thing.
i can shift just as smoothly at 2500rpm as 6500rpm and anywhere/any throttle in between. |
Toofah King Bad
Odd problem.
I probably get up to 5k or so in first driving around. . .but then I also run up second and end up going 1-2-4.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
What v-2 and Rasta said. Depends on the situation. Remember - Practice makes permanent. Good luck with the shifting thing.
1984 Porsche 944 NA |
plays with toy cars
~3500, sometimes the shift is crisp and sometimes it takes a second or so for the synchro to catch on. In my car it seems to be a function of the gear oil temp primarily.
1983 944 - modded everything http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317 '86 951 - under construction http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374 |
I shift to 2nd anywhere between 5mph to 35mph. Don't forget to match RPMs with the right foot. For example, these two different shifts:
1st -> 2nd @ 20mph
1st -> 2nd @ 30mph
The trick is to match the engine revs to what the resultant revs would be in the next gear before you let out the clutch. Then flywheel & clutch-disc would be at the same speed and the synchros don't have to force the engine up or down to match. If you do this rev-matching cleanly, you can even shift without using the clutch at all. ![]() Last edited by DannoXYZ; 06-10-2015 at 10:03 PM.. |
Misunderstood User
I try to shift to the tach 3000-4000 rpm. I don't have any problem shifting at any rpm. I can go from 3 to 4 w/o using the clutch too.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
Ben Selby
I played with it a little today and it is alot easier shifting at a higher rpm. I'm use to driving vehicles you shift around 2500 rpm, but it is easier around 3500rpm. Part of my problem is that I wear a size 13 shoe and I have to where my work boots driving it to work every morning. Lol
Ben Selby
Another of my problems is that my exhaust vibrates at 2500-3000 rpm so I try to shift before then to avoid embarrassment. Lol I have a whole new exhaust system ordered I'm just waiting for it to come in.
Check your balance-shafts' timing as well.
The smoothness of your shift can depend on how well the engine idles. Once I had fixed an intake manifold leak, wires, plugs etc. my 87 shifted from first to second much, much smoother. The idle was never terrible but getting the engine running better will have a huge effect on the shift from first to second.
1987 944 Summer 2006 E90 Winter |
Lol, about 15mph but I drive like an old man until 3rd....then I am 22.
make sure your shift linkage is lubed up, working right etc and get your timing right ![]() |
plays with toy cars
I wear size 13s and my 944 is way easier to shift than a lot of other cars. I was driving a friend's e36 and was hitting about everything else besides the clutch pedal.
I can shift my 924S up to second at about any rpm and the engine responds smoothly. You have an engine issue, maybe vacuum leak or some tuning issue. Start with the basics, the simple stuff.
Jon
87 924S 82 924-Gone. 80 924 parts car-Gone. |
i find one of the keys to a smooth shift is not to push much on the clutch pedal. i push only enough to release the tension on the shifter and change gears.
Ornery Bastard
Those of us who don't want to have to tear down the transaxle every 50,000 miles or so would benefit from releasing the clutch completely for each shift. Your recommendation is basically that, instead of completely disengaging the clutch, he let is slip a little and force the synchros to overcome the clutch drag. This is hard on the clutch and, more critically, hard on the synchros. It's a ridiculously terrible idea for someone who drives the car every day.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
Toofah King Bad
Note to self: never let flash drive your car.
I'm too easy on my cars but 3rd gear? Then the fun begins. Once in a while 2nd gear gets a bit of a work out but I like the 944 because it has enough torque to short shift. |
