944 Turbo strange problem with tranny
My 944 turbo will not shift into gear when running but will operate normally if i select the gear when the car is off. When the clutch is fully depressed the car does not lunge forward.
There is no transmission noise either. Everything feels and sounds the way it should except that I cannot change gears when it is running. My first thought is clutch but it has been sitting for some time before this started. Has anyone else experienced a similar problem? |
It almost sounds like a stuck clutch disk from sitting but one of the things you say does not fit: "When the clutch is fully depressed the car does not lunge forward". It'd be worth trying the stuck clutch disk protocol. Put it in 5th with the engine off and hold the clutch down while having someone push the car, see if it pops loose. You could also probably use the parking brake and start the engine.
Otherwise it may be a broken clutch spring.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
if you put the trans into 1st gear and then crank the starter, does the car move forward?
In the Fires of Hell.....
Sounds like your clutch is on its way out. I have had the same thing on mine just before I changed it.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
You could have air in the clutch cylinder or a bad clutch master or slave cylinder. I have seen them have a slow leak so you don't get full travel and the clutch never fully disengages. If it is a slow leak you can just bleed the system and see if that helps. On of mine has a slow enough leak I just need to add fluid every month or so.
Toofah King Bad
Second the hydraulic problem. If history of the clutch master and slave are unknown, replace both, along with the feed and pressure hose.
Full hydraulic flush WYIT.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
