suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
I'm vibrating..
When I rev to 4000 in first then shift to 2nd I start to notice a (rubbery) vibration as I approach 4000 again, when I make the shift to 3rd.. it becomes a strong vibration I have to dump into 4th and back off, or it's ridiculous.. also when I shift slowly, something (Clanks) in the shifting.. .. someone please advise...
Frank B
My car is naughty
Old 11-13-2002, 08:35 AM
SoCal Driver's Avatar
Clutch time!!!!
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-13-2002, 08:36 AM
Scott R's Avatar
Did the 86 na still have the hockey puck clutch? I can't remember I know my 85.5 did.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-13-2002, 08:45 AM
AFJuvat's Avatar
Yea verily, thine clutch is preparing to depart this mortal coil.
Pelican does have about the best deal around for a clutch - the whole shebang for about $700 - includes just about everything you would need.
One thing to add though - change out your flywheel seal while you are in there.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-13-2002, 08:46 AM
AFJuvat's Avatar
Yep, the 86 had the hockeypuck. I think all of them came with it stock - can't remember.
AFJuvat
Old 11-13-2002, 08:47 AM
suck my tail pipe
Frank B's Avatar
O.K... good advice.. thank you. I'm going to have the Timing belt waterpump.. pulleys etc.. done.. should I do the clutch done then?.. also, when I have the belts done will I notice an improvement in the performance, or will it be similar to how it is now?.. just curious...
Frank B
My car is naughty
Old 11-13-2002, 09:06 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Just pulled mine out......and yes...hockey puck (86' NA)
Not bad for a clutch with 240,000 km (~150,000 miles)
Mine was vibrating at 4,000 as well....but also a nice grinding sound with the clutch disengaged (throw out bearing - TOAST)
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 11-13-2002, 09:07 AM
AFJuvat's Avatar
you will have the same performance.
Will probably noticie a difference when you replace the clutch
AFJuvat
Old 11-13-2002, 09:46 AM
944S Boyeee's Avatar
Send a message via ICQ to 944S Boyeee
Speaking of clutches....
When my car idles high - around 2000 (sticky ISV), I can feel a slight vibration (more like a fast "thumping") in the actual clutch pedal. No vibration at regular idle speed (800 rpm). It doesn't do this all the time though.
Is this a bearing?
944S Boyeee
Old 11-13-2002, 01:27 PM
