Aey Aey is offline
Vented Gas Cap for Early 944
I have an excessive pressure/vacuum in my gas tank. I don't have any canister filter in my engine bay. I don't know if it original came like this or the PO modified it. My fuel line goes straight from fuel pump to fuel rail. I heard that there is another vent in the filler neck area, but I guess it is clogged.
I don't want to drill my NON-VENTED cap. I think the VENTED gas cab is the easy fix to my problem.
Can anyone give me the link to the VENTED gas cap that has the same thread and will fit my early 944 please. Preferable of Pelicanparts website.
Also I heard that VW Golf MK1 VENTED cap will fit. Can anyone give me the part number please.
Thank you for your help.
RHD '82 944N/A
Old 07-13-2015, 08:29 AM
txhokie4life's Avatar
I am interested as well.
Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 07-13-2015, 10:32 AM
jhowell371's Avatar
I just used a cheap replacement and removed the valve. The pressure build up in the tank of my 87 16V VW Scirocco would make a hell of whoosh when you opened the gas cap. My 84 944 did too, so I knew the tank wasn't cracked and I vented it to keep it from cracking
Red 84 w/25,xxx miles
Stone Gray 89 S2 w/90,xxx miles
Old 07-13-2015, 12:54 PM
The charcoal canister is in the driver's side wheel well.
87 924S
82 924-Gone.
80 924 parts car-Gone.
Aey Aey is offline
My car doesn't have the charcoal canister.
It's RHD '82 944 in Thailand and gas vapor is not on the emission control here.
After 15 minutes drive, my fuel pump always get really loud and the car hesitate at all rpm. Tried changing fuel pumps, FPR, and FPD, and cleaning injectors with no success. Until one day I found out that my fuel tank has a lot of vacuum, so I run the car with gas cap not screwed all the way in and all problem is solved.
Now my car run with the rubber o-ring off the gas cap, but it's not safe in case of accident. I really need the vented type gas cap to fix this problem.
Please help.
RHD '82 944N/A
Old 07-13-2015, 10:11 PM
810 201 186 A is the bleedeer valve, sometimes called the two way valve that controls pressure in the tank. It is common to VW and Audi and is known for allowing too much pressure to build up in the tank. Some have removed this valve (not recommended) and some have used valves from other cars.
Gas fumes? Tank leaks? Read this.
It's unsettling how much pressure these valves allow. But at least you know your tank isn't cracked!
Jon
87 924S
82 924-Gone.
Old 07-14-2015, 03:08 AM
p-talk's Avatar
True. Someone used a Mitsubishi valve with success, but I was never able to find that part. I modified a 1970s Mercedes valve, and it works well as a replacement.
Jon
1984 Porsche 944 - Mathilda the needy
2014 Audi Allroad - daily driver
Old 07-14-2015, 07:48 AM
Aey Aey is offline
Thank you for all replies about the valve. I'll definitely change the valve when I have time to remove the interior trims and get into the filler neck.
Meanwhile a vented gas cap is an easier and safe fix for me. Just need to know which one is compatible to an early 944 please.
RHD '82 944N/A
Old 07-14-2015, 09:14 AM
Aey Aey is offline
Stant # 10817 seem to be the vented cap that I'm looking for base on these information;
FYI: Vented Gas Cap Part #
Random Thoughts, kaidouza70: Got my Stant 10817 vented fuel cap...
According to Stant's website, the cap # 10817 fits our 944. It's only 7 bucks, so I'll give it a try. Will keep you guys updated, when I tested it out.
RHD '82 944N/A
Old 07-15-2015, 03:46 AM
