86 944 low pressure switch
Where is the low pressure switch found on the 86 944?
Custom User Title
For the AC? Next to the drier.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
^ behind the driver-side headlight, attached to the frame rail.
thanx guys, I found it but not understanding how it interacts with preventing voltage getting to the compressor. Any tips?
if the pressure is too low then the switch activates and wont let the compressor turn on via the ac relay, iirc.
if you are testing compressor function or charging the system you can jumper the two contacts |
