Send a message via Skype™ to massive
Body work repair
Once the British winter has come and gone I intend to get some areas of the my 944's bodywork repaired.
The main areas that need attention are as follows:
1. Hood, clearcoat is breaking down and some very light brown rust spots appearing
2. Offside wing, clearcoat is breaking down also has some obvious rust bubbling beneath the paint surface on the lowest section of the wing.
3. Nearside wing, clearcoat is breaking down, has some minor surface rust on the lowest section of the wing.
With regard to the repair work needed I think the hood is not too bad and may just need a sand down and respray. The wings however I'm considering replacing or having the rusted areas cut out and new steel welded in its place. My question is hows does repair work affect the existing galvanising? Is it worth having the wings stripped and then regalvanised?
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 10-07-2014, 02:57 AM
curtisr
curtisr's Avatar
Source: http://www.zinkpower.com/media/files/arbeitsblaetter_englisch/2_10.pdf
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 10-07-2014, 04:01 AM
jeff968's Avatar
Sorry for the silly question but what is a "wing"? Are you talking about the front fender and rear quarter panel?
Old 10-07-2014, 06:01 AM
Are you talking about guitars?
But yes we are talking about the same thing Fender (vehicle) - Wikipedia, the free encyclopedia
Old 10-07-2014, 06:44 AM
jeff968's Avatar
Thanks, I don't speak UK i need to watch "wheeler dealers" more often.
IMHO, rust repair is rare on our cars. Even here in New England I don't see many 944s with any kind of rust through. This is usually attributed to the excelent coatings that were applied at the factory. If i were you i would look for good quality used parts, which should be easy to find and cheap to purchase, and use them and avoid any type of patch repair work.
Old 10-07-2014, 08:20 AM
Yep I was thinking good quality used parts are the better alternative, but it still doesn't get away from the fact that the innner and outer coatings will be 30 years old and since I will need to have the parts resprayed anyway I thought that it may be better to have them stripped first and then everything applied from new from the ground up.
Old 10-07-2014, 11:28 AM
jeff968's Avatar
There is a guy somewhere here in the US that has a used foreign car parts store. He has had an early eighties 944 permanently mounted outside of his building for years and it still looks great with the factory paint and no rust. A true testament to the quality of the Porsche 944 body and paint.
Old 10-07-2014, 11:35 AM
I agree, they do age well, even in the British weather.
Old 10-07-2014, 10:34 PM
FrenchToast's Avatar
Porsche pulled a similar stunt in the seventies. In '77, with fully galvanized cars (924 was not fully galvanized until later), Porsche put a Targa shell outside the factory, without any paint or primer and parts only for it to roll. Had it out there for 7 or 8 years? Whatever the warranty was. Presumably it did fine.
That's all well and good, until you start putting seals, hardware, and parts on a car. And then drive it, dirt collects, drains get clogged, it holds water and wham.
All that said, this era of Porsches have some of the best rustproofing out there.
Unless new wild chemical formulas debut, cars from the current decade and newer are all much worse. The steel is lower quality. The primers and paints are all lower quality by mandate.
As noted, galvanizing is removed in order to weld. Assuming you are referring to the front wings, the easiest solution would likely be to source clean used examples and have them painted. A good automotive painter can blend the paint to match the original paint.
If you are talking about the rear wings, yes the optimal solution is to cut out the rust and replace with new metal and prep it properly for new paint. Hopefully it's the front wings!
For the clearcoat you might be able to get away with sanding it down to base coat and re-clearing it. A good automotive painter should be able to direct you if this is possible.
If you have rust there you should also check the rockers, under taillights (especially if they have been poorly resealed after-factory), check for chips by the hatch latches, and battery tray. Regardless of if your battery is in the front or rear, you should check it. Also check the floor and undercarriage for stray chips in the undercoat.
Good luck!
Old 10-07-2014, 11:16 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
The sills have always gone on these cars, but the rest is usually rustfree except when previously badly repaired.
Post '81 924's don't seem to rust as readily.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Last edited by Mark at Pelican Parts; 07-16-2015 at 12:32 PM.. Reason: per petrolhead611 request
Old 10-08-2014, 07:45 AM
Can comment 10 please be deleted urgently Admin
Old 07-16-2015, 04:00 AM
less I know,more I learn
Backyardbodyman's Avatar
My 2 cents. I treat bare metal with a good metal conditioner and epoxy primer. Conditioner cleans and leaves a zinc chromate film. Some guys use self etching primers to avoid this step. If you have deeply pitted rust that cannot be fully removed by sand blasting or chemical dip,cut it out or it will eventually come back. Rust never sleeps
Raymond
Old 07-16-2015, 10:32 AM
