What are the best spark plugs for my 1984 944 NA? I just pulled and checked and there were NGKs installed. I'm thinking Bosch 4477 Platinums. What are your thoughts or opinions? Thanks!
1984 Porsche 944 NA |
I like NGk more. Copper is better than platinum except they don't last as long. Given how easy it is to change our plugs, I opt for copper and swap every 60k mi
it will run better on old school plugs ..I run $2 ngks
Bosch Super Plus copper
NGK is best.
Platinum isn't worth it unless your plugs are hard to change, which they aren't on a 944. |
Engineer of profanity
NGK is crap. I wouldn't put them in a lawn mower. Every motorcycle I've ever owned fowled NGK spark plugs. Do yourself a favor and use Denso Platinum TT's the number is 4502. These plugs are the best thing I've ever run in a Porsche 944 or 928 engine. Something about these U-groove plugs wakes the engines up pretty nicely.
I spent 6 months throwing parts at my '83 928 to make it run like my '84 928. I finally figured out that it was the spark plugs. As stated people seem to like NGK's but I quit them a long time ago. Get a couple of 2 stroke dirt bikes, or even a street bike and see how many times you get stuck out in the woods or your bike won't start when they get just slightly old. You'll curse them after that. Trust me...
1970 Porsche 911T Black 1990 Porsche 944 S2 Red on cashmere 1984 Porsche 928S Euro ROW GP white on black |
![]() maybe the plugs you were using were the wrong heat range if they got fouled. i just swapped plugs on my 944 for the first time since 2005, never had any issue with the old NGKs, so new ones went in...only replaced them because i was doing some other work anyways. |
The quad tip bosch, which Audi used starting in the early 80s, i believe was to aid with cold starts...they where high dollar back then.
I am not much on foofoo plugs. Yes, that special tip will last longer but it is usually the grounding electrode that wears away and increases the gap. Old school cars, you changed the points and plugs every 10k or so...back when plugs where easily accessible. Modern cars have made plugs inaccessible so hence the need for forever spark plugs. In my opinion....Huge gaps increase the resistence so that also increases the chance of tracking and arcing in the cap...which goes through the magnesium housing...then you have drama))lol |
H6 tribeca, the early one....coil on plug so the motor needed to be lowered to swap them.
Fabulous motor....does suck down some oil if you pound the redline for an hour. |
OT, but do you guys use the subaru coolant additive? It is supposed to make the head gasket last longer.
My ex roommate is going to sell me his 2 door RS when he gets something else payed/paid off. Non turbo but wicked fun. Bears have trashed it, an 01 and no fluids have ever been changed except for the engine oil and the coolant when a metal heater line rusted out. Poor car but it is a two door. |
plays with toy cars
About to get OT...Helped a friend do plugs for the first time on his 2010 Forester NA and there was one where we had to get creative with u-joints or something, it was hysterical. He watched me do the plugs on my 944 and was immediately annoyed at how easy it is on these cars.
Re: Subie coolant... there was an issue where the coolant contributed to HG failures because it was getting electrically charged or something. Just what I've heard from Subaru buddies and NASIOC posts. I think it was something to do with the coolant chemistry. On topic, my car has been problem free on NGK BPR5ES plugs. I've pulled them a few times and they are fine.
1983 944 - modded everything http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317 '86 951 - under construction http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374 Last edited by sausagehacker; 07-27-2015 at 11:20 AM.. |
head gasket was done maybe 2 years ago. i have service records ! i havent done anything to it except change the oil, put steering rack dust boots and tie rod ends on it, so i don't know about the coolant but i suspect it was the cheap stuff. your RS should have the same engine as my car, i think the 01 was the last of the 2.5dohc motor in that car. good car, but anything but fast. |
If you ask me the 100k sparkplug is the greatest invention since sliced bread... |
I had problems with iridium plugs fouling. Changed to Bosch Super Plus copper and never had a problem. My owners manual for a '91 S2 stipulates Bosch Super Plus. Speaking to specialist shops who prepare 944 race cars they all recommend the Bosch Super Plus too (for road and race) so that is what I've stuck with.
Annother annoying thing about the platinum tips is sometimes they get loose and fall out. Then shorts out against the ground-electrode and causes misfires. Or in unlucky cases of the X4 plugs, the loose electrode can get jammed in the rings and cause major damage to the bores.
Yeah, I've had way better performance and longevity with the NGK copper plugs compared to any of the boutique plugs. |
I just went back and checked, and these were what I put in my NA:
Bosch (7900) WR7DC+ Super Plus Spark Plug With the Bosch premium hi-temp silicone coated plug wires and new distributor cap and rotor, it sings. Prior owner had the quad tipped platinums, but they were coked and looked raw. Figured fresh OEMs would be better. |
