idles rough spits and back fires threw exhaust and wont rev
Can't figure this out got good fuel pressure all spark plugs firing injectors are spraying and can't get it to do.more then idle like crap and pop out the exhaust pops black smoke it almost looks like. If you rev it it dies. Starts right back up but just goes back to idling like crap please help thanks
Order a replacement fuel pressure regulator, fuel damper, and fuel filter and be patient. There is no such thing as a cheap Porsche.
PCA - Florida Citrus Region |
Already checked fuel pressure and fuel.filter is on itd way
944 addict
A loose connector on the AFM, spark plug wires in wrong order, bad or misfiring injector, timing belt skipped a tooth. Also check for a vacuum line pulled loose.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
All that's good other then timing could be a possibility. What about the dme? When they go bad are they just bad or can it do something like this?
My friends call me, Top
I would suspect the timing is off. Your description and troubleshooting point to timing.
Matt '87 924S |
When is the last time the car was running well? How long did it sit for?
My guess would be 2012 sense the oil change sticker is from 2012 and the mileage is only 212 miles on the nee oil change. So 2012 is my guess and you think itd just s tooth off or something
Timing looks fine also
Backfiring indicates that ignition timing is off. Since the ignition timing is controlled by the ECU, the other possibilities are the rotor (not pointing in the right place) or plug wires incorrectly positioned in the cap. Could also be the ECU is bad (very unlikely). What type of 944 is it?
Good luck, George Beuselinck |
plays with toy cars
The AFM would be the second thing to check after the timing.
This is how I did mine: https://www.youtube.com/watch?v=4pFxhJO4jXc
1983 944 - modded everything http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317 '86 951 - under construction http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374 |
How about a weak ignition coil.
SOunds just like mine when I did plugs, wires and rotor.
I had cylinders 2 and 3 transposed on the distributor. |
As stated above- I would definitely check the spark plug wires
Also Remove the J-Boot and make sure there are no cracks in the rubber, while the boot is off verify that the door on the AFM (air flow meter) is moving freely - (I was helping a friend bring a 944 back to life, and found the door inside the AFM was sticking causing some rough running issues) |
