Car died when i turned the ac on please help.wont restart
Started the car up this morning second day of getting it to run good now and turned the ac on and the car just died right away no spit no sputter just died and now it crsnks has spark and has fuel pressure. Wont even try to start please help was hoping to get plates on the car today and make it legal thanks
Old 08-05-2015, 08:13 AM
Proprietoristicly Refined
John_AZ's Avatar
1. Check the NEG ground on the engine block.
2. Is the battery fully charged?
3. Check the fuse block for a blown fuse.
4. Does the tach needle bounce 1/16th of an inch when you crank?
5. Change the DME/Fuel pump relay. URO brand cheap and bad>
6. Check the connection to the AFM.
7. Did the AC compressor B+ short to the frame? (12 inch wire from the compressor to the frame connection)
and...
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 08-05-2015, 09:27 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Is the compressor locked up?
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 08-07-2015, 03:55 PM
