89 S2 Coupe Speaker Upgrade
Probably a repeat question here folks, but what brand/model of current 4 x 6 speaker fits into the door slots without any modification? I have the standard four speaker set up. I'd like to use the factory grills as well.
Thanks for the help
Old 08-04-2015, 01:02 PM
Will try the Infiniti kappa's.....thoughts?
Old 08-04-2015, 05:32 PM
MBruns for President
JeremyD's Avatar
try crutchfield - they are pretty good about what will fit and how easy an installation will be
Old 08-05-2015, 07:07 AM
Other thoughts??
Old 08-05-2015, 01:40 PM
911lnv87's Avatar
Soundstream PCT.462 speakers work in the front door as well as in the back
Porsche 944 Turbo - Graphite Metallic - 2.8L - 1986 DD
Porsche 944 S2 Cabriolet - 1990
Porsche 944 n/a - Dark Blue - 1988 - Sold
Old 08-05-2015, 03:42 PM
Kappa 4 x 6 in the front and 6" in the rer work and are both very good. Front grilles fit over the kappa fronts but you need to rig up a method to keep them there ... they don't quite reach the OEM clips. I retained mine with dabs of silocene that you can't see and works well. I have some pics somewhere that I will pull out. I have some pics I think. Might take a day or two to find.
Old 08-06-2015, 02:26 AM
Thank you
Old 08-15-2015, 05:56 PM
Originally Posted by jep32 View Post
Thank you
Most new speakers are too tall because of the midrange/tweeter centers although there are some that fit. Sometimes there is a spacer underneath or trim piece on top that can be removed to lower the profile enough to fit under the grills.
Old 08-16-2015, 03:32 AM
My 944 scares adults
lovemy924S's Avatar
Send a message via AIM to lovemy924S
I've never had any issues getting 4x6's to fit in the doors, but I don't think plate speakers fit...often standard 4 point attachment speakers come with a plastic spacer that goes around the edge under the bolt holes, I've used this in front of the speaker plate/mounting points to space out the plastic cover 1/4 inch from the face of the speaker.
The 4x6 (Pioneers??) I have in the doors on my Turbo fit without the spacers, but JUUUUUST barely...not the highest quality but they sound pretty decent!
1987 Porsche 944 (black) with a 1997 LT1 5.7L V8, BBK 58mm TB, fully ported intake, LT4 Hotcam, Comp Cams 1.6 Rockers, LS1 MAF, Custom Dual 3 inch exhaust through 2 Flowmaster 50 series mufflers
1986 Porsche 944 Turbo, 1989 944 Turbo S engine with K26-8, MBC, knockoff Turbo Twist wheels, test pipe, Ansa cat-back, Chipped (Auto-Authority?)
Old 08-16-2015, 10:11 AM
jeff968's Avatar
I did not make out well here with the same question. I ended up getting some new replacement speakers from Porsche and I had my rear speakers re-coned.
Old 08-17-2015, 07:02 AM
