1.2gees's Avatar
Send a message via AIM to 1.2gees
Oil Leaks!!!
OK, yesterday I replaced my oil pan gasket for the 4th time (or is it 5th) and it got blown out within 10miles, running 14lbs of boost... Every seal on this car has leaked and been fixed at some point in the last ~10k miles (11months or so). Current offenders are the oil pan gasket, and what appears to be either crankcase vent (oil air seperator), or drivers side balanceshaft housing.
I need to figure out why all my seals are leaking, running out of ideas here. My best guess is that the air/oil seperator is clogged, please help me, this is VERY aggrevating. Compression is good, so I don't think blowby is really an issue.
Ahmet
Cheers!
Old 11-18-2002, 11:40 AM
The only way the oil pan gasket will blow out is either by poor installation or excessive crankcase pressure. 14lbs (.96 bar) of boost is not much above stock anyway. You may be having a blow-by problem.
Have you checked the breather system? you need to be sure that the crankcase is not being pressurised by an incorrectly assembled breather system.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 11-18-2002, 12:59 PM
1.2gees's Avatar
I doubt the oil pan gasket installation was faulty, I also don't think I have an 'excessive' blowby problem. It hasn't been long since I rebuilt the engine (dirty rebuild though), and the compression is only .5psi off spec for a new engine. What I'm guessing (hoping, oh god!) is that the [problem comes from a clogged/malfunctioning breather as the oil pan gasket is not the only seal/gasket that's leaking or has leaked.
Is there any way to check the air/oil seperator +breather?
Ahmet
Cheers!
Old 11-18-2002, 01:58 PM
I have never been able to stop the oil leaks in mine either. Right now I am leaking where the head meets the block near #4 but on the side. It has been coming down the outside of the block for at least a year. I put a new head on it about 4 years ago. I also think I am losing some from the rear of the oil pan gasket but that could be coming from above. It is aggravating. I was very careful with the pan gasket when I did it last January. I also find oil at the end of the three metal lines that go across the top of the block under the intake. I suspect the connection where the metal meets the rubber is leaking a little because that rubber hose is wet. I plan on removing the intake after the Charlotte DE. I also have a little oil leaking from where you fill it. A drop forms on the O2 cable.
Old 11-18-2002, 02:36 PM
AFJuvat's Avatar
Ahmet
Other than by disassembling it, no.
I am getting ready to do my whole vacuum air/oil seperation and associated seals.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-18-2002, 06:10 PM
there is a cork seal at the back of the engine, at the end of the
?cam tower? the thing that says porsche on it, haha i'm an idiot i know. That seal goes bad a lot and leaks a ton of oil, it drips down the back of the engine and makes it look like its the oil pan seal, i may be wrong but i bet some of you guys have that problem and not the oil pan, that cork seal get hard and brittle and just falls apart
Old 11-18-2002, 08:14 PM
AFJuvat's Avatar
Thanks for reminding me - forgot to order that one.
Old 11-19-2002, 02:22 AM
I'll check the cap at the end of the cam tower tonight. I resealed it about 6 years ago without a gasket - just used Permatex. Last time I looked (about 6 months ago) it was not leaking. It would be nice if that is my problem....
Old 11-19-2002, 04:09 AM
