lights keep poppig up and then closing...and then popping up
It goes on for about 3 minutes.
Anyway, what can i do? Is it the relay? Or should i turn the motor a few turns? Driving me bloody potty best MJ |
Hi, I have had this problem too - I found it to be the relay that is mounted on the headlamp motor. Simply replaced this and the problem was solved - so it could be that, if you have an alternative relay to try - give it a go. Otherwise it could be the contact tracks inside the motor itself.
Yep, relay by the motor.
| All times are GMT -8. The time now is 10:12 AM. |
