FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
'83 944 Balance Shafts
I first would like to thank all of you for all the help I have rec'd
by just reading thru the pages.
I have an '83 abused 944 I loving call the "Bright Red Money Pit"
I could tell you all I've done to it but would be easier to say what I haven't done.
The question I pose I could not find in documentation I have. The upper and lower balance shafts have in/out play of a little greater than 1/8". Is this normal? Do the shafts center based on the crank pulley?
Is there a trick to removing the Camshaft Gear. I attached my gear puller and it slid out about 1/16" and stopped any more pressure I was afraid the gear would break. Are there any locks/keepers on the inside? Seeing as it would not come out I tightened back up now the retaining bolt hole does not line up by about 1/32". What did I do wrong? All I wanted was to bead blast the box.
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 11-21-2002, 06:14 AM
AFJuvat's Avatar
Yes, there is a bolt in the camshaft that holds the sprocket in there, You will need to remove it before the camshaft pulley comes out.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-21-2002, 07:03 AM
FLA944's Avatar
Mike,
Did that. Only way to remove the nut.
Old 11-21-2002, 07:14 AM
AFJuvat's Avatar
Awww Hell...
The woodruf key is probably snagged on the pulley. PB Blaster is your new best friend!
Soak it down let it sit for a bit, then give the pulley a few light raps with a rubber mallet to try and work it loose.
Mike (AFJuvat)
(Did your friend sell the 928?)
Old 11-21-2002, 07:18 AM
FLA944's Avatar
Mike,
Soaked the heck out of it. I will try rapping with a mallet while applying pressure with the puller.
The previous wrench on it nicked 1 tooth on the cam gear. Should I replace it?
He really boogered up the balance shaft gears I am replacing.
I did start the car to test the lower end and it ran smooth as silk no smoke, knocks etc..
Consider the 928 gone. I get nothing but conflicting statements on the car. re: Yes it's sold, no it isn't, It's a 924 no wait 928 no wait again 968. I don't think the nut knows anything.
Old 11-21-2002, 07:30 AM
AFJuvat's Avatar
Well, that depends - how chipped is the pulley, and how rough is the chip?
Soak it down again and let it sit - even overnight. Then rap it a couple of times.
He probably tried to remove the gears with a set of vice-grips - a "common" problem. Screws everything up.....
Damn, sorry to hear its gone, would have been an interesting one to play with for a while.
Mike (AFJuvat)
Old 11-21-2002, 07:54 AM
FLA944's Avatar
There was a 944 on ebay later back ( read on previous postings) that was up in Cocoa. Sounded like the "older than me" dude did not know what he had either.
Sounded like a mid life, balding, limp @#?!, kind a guy.
Check it out may still be there.
It definately looked 120% better than mine.
Old 11-21-2002, 08:05 AM
