need picture of headlamp assembly
I tore apart the passenger side headlight to fix some body damage. I had the headlight motor out and the entire headlight and all mounts. Put it back together but I got something not right. The spring goes limp when the motor arm turns. The drivers side still works fine. I figure I just have the spring or arm position wrong. I messed with it for a little while and couldn't figure it out. I'll keep trying but if somebody could take a picture of the arm position and where the spring clips on that would be real helpful. all my searches here and on the google have come up empty.
Don
Running Cars
06 Boxster S, 85 944, 83 928S
Project Cars
74 914, 74 911, 72 914, 66 911, 65 912
Old 09-16-2015, 10:51 AM
M. Murphy's Avatar
Hope this helps.
Old 09-16-2015, 12:16 PM
it helps because I can now see the proper arm position with lights up and down. Any way to get a picture from the opposite angle so I can see how the spring is clipped on?
Running Cars
Project Cars
Old 09-16-2015, 12:20 PM
M. Murphy's Avatar
Let's try this.
Old 09-16-2015, 06:30 PM
curtisr
curtisr's Avatar
Hope this is helpful:
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car)
1987 924s Garnet Red (with FIAMM air horns!)
1982 928 Silver (sold)
Old 09-17-2015, 02:55 AM
thanks guys for the pictures. really helped. figured out it wasn't the arm position or how I hooked the spring on. I was missing a piece, #18 on the diagram and the arm wasn't resting on the v-shaped piece and pushing the light up. I knew it was missing and thought it would work temporarily until I replaced the part.
The story on this car is it has been wrecked multiple times. a previous owner hit that front, passenger corner and it was all out of alignment. Fender and light were crooked, hood rubbed, etc. It was put back together and worked but he had it all rigged up. I took it all apart, hammered it all back to the correct shape. Put it back together but when I remounted the light it didn't work anymore. It is missing a bunch of the parts for light housing and mounting. Now that it is straight I just need to find all the missing parts and put it together correctly.
Thanks again for the help.
Running Cars
Project Cars
Old 09-17-2015, 08:48 AM
I have a complete headlight assembly and a lot of random parts left from taking apart four cars. Send me a message with all the parts you need and I should be able to help you out.
Currently have: Guards Red 1987 924S 16v -- Light Blue Metallic 1980 928
Gone: Minerva Blue 1979 928 -- Gray 1985.5 944 -- Black 1989 944 -- Black 1984 944 -- Black 1987 944S -- Alaska Blue 1974 914 1.8 -- Guards Red 1983 944 -- Guards Red 1987 924S -- White 1988 924S -- Maraschino Red 1987 944 Turbo -- Beige 1981 924 -- Red 1984 944
Old 09-17-2015, 10:19 AM
