944 Won't Turn Over
So I have an 83 944 that as the title says, won't turn over. I drove the car, went to the local car wash and manually washed the vehicle. I then drove the car home and went to start it later (maybe 4 hours) and all I got was a humming noise from the fuel pump. No noise or movement from the starter or solenoid.
Ordered a new starter from Napa and after 3 days, received it and installed it. Go to start the car and still have nothing from the starter. Although the starter did not look like the one I took off, I thought that it was a basic connection. My original solenoid had 3 bolt terminals, 2 larger studs for the larger wires, and then 1 smaller stud for the "trigger". And then obviously the terminal that attaches to the starter. My new starter has two stud terminals and 2 spade connectors. One of the stud terminals goes to the starter motor and the other I attached the 2 large wires. I then cut and crimped a female spade connector to attach to the bottom spade connector on the solenoid, leaving the top spade connector empty.
Needless to say I have no idea what is wrong. I have not tested the starter or put a multi-meter up to the cables to see if I have power but is there something obvious I'm missing? I checked the ignition switch but everything checked out, and I also swapped that out probably a year ago when the switch officially went.
Just looking for some help, and thanks ahead of time obviously.
Old 09-18-2015, 02:29 PM
winter-hater club member
nynor's Avatar
starter switch?
"COOL PRIUS!" - Nobody Ever
Old 09-18-2015, 03:04 PM
Patrick
pfarah's Avatar
You may want to inspect/replace your ignition switch. It's actually an easy job.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 09-18-2015, 08:16 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Did you check your battery connections and the battery ground on the top of the bell housing?
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 09-18-2015, 09:21 PM
911tracker85's Avatar
did you try jumper the solenoid to see if the starter will turn over?
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 09-19-2015, 07:34 AM
Toofah King Bad
Rasta Monsta's Avatar
+1 on the ignition switch. Cheap, easy to replace, and a required maintenance item due to bad design and materials.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-19-2015, 08:11 AM
