Dignan's Avatar
Question Can you adjust the clutch to get a bit of extra life out of it
Hey Guys..
I am looking at a 83 944 for a Daily driver.. and was wondering one thing tho. I know lots about the 911 but not much about the 944 can the clutch be adjusted to get a little bit more bite out of the clutch?
Thanks in advance.
E.M.
78SC
I'll take a liter of Cola.
Old 11-22-2002, 06:55 AM
Scott R's Avatar
No, it's hydraulic. I adjusts as you go along, just add more fluid.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-22-2002, 06:59 AM
Dignan's Avatar
Hey Thanks Scott,
See the 911 has a cable that can be adjusted... i'll see if that helps.. if not i may walk away from it.
Old 11-22-2002, 07:01 AM
SoCal Driver's Avatar
Very difficult to "adjust" a rubber center clutch disk that has come apart.
The 944 clutch "IS" or it "AIN'T".
Note: A separated rubber center clutch disk has a noticeable amount of movement from acceleration to deceleration and a loud clank at each end of movement. The replacement is a spring center disk. Besides having to take half the drive train out it's not that difficult to do. In many cases you can get away with just replacing the disk.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-22-2002, 07:02 AM
