Have 944, will restore
mazdaverx7's Avatar
You have to be kidding me..
Decided to check the timing and balance belt on my 85.1 944 and came across something very startling... I pulled back the timing cover and discovered the previous owner did not install a balance belt on the engine when the last timing service was completed.. What the heck? Not a ton of engine vibration but its not as smooth as my 85.2. Time to put a balance belt on the car instantly if not sooner.
85.2 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE
Old 09-18-2015, 12:34 PM
winter-hater club member
nynor's Avatar
that is good for about 50 HP.... LOL!
"COOL PRIUS!" - Nobody Ever
Old 09-18-2015, 02:06 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
While you're in there it looks like you might check all the rollers and also replace the timing belt.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 09-18-2015, 08:28 PM
Bradical's Avatar
Id do a full belt job too, as my777 said.. Those gears and rollers, especially the timing belt tensioner, look like canine feces.
PCA - Florida Citrus Region
Old 09-19-2015, 05:37 PM
mazdaverx7's Avatar
Took a pic of the car before I started the teardown:
Pics of where I'm at currently. Got the engine to TDC and am awaiting a new timing and balance belt and a new little bolt that holds the ignition rotor in place:
Old 09-20-2015, 03:38 AM
I second the opinion to replace all rollers & idlers while you're in there.
I learned the hard way when I replaced only the belts last year only to have the timing belt idler freeze this summer and force the camshaft out of sync. $1,400 in parts ($325 to a machine shop to resurface the head & install valves) later, I'm now dealing with lack of oil pressure problems.
So, when it comes to Porsches, while-you-have-access to a part, don't cheap out. Replace it!!
Check out the pix.
Old 09-22-2015, 12:30 PM
Patrick
pfarah's Avatar
Ouch!
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 09-22-2015, 04:00 PM
nynor's Avatar
oy!
Old 09-22-2015, 04:22 PM
Just thinking out loud
mattdavis11's Avatar
Two things I see wrong with Leo944's car. Belt guide on the water pump, and larger cam belt idler. The early cars don't need either, ever.
91 FJ80
84 Ram Charger (now gone)
Old 09-22-2015, 05:55 PM
nynor's Avatar
i disagree. but we can still be friends.
Old 09-22-2015, 06:32 PM
mattdavis11 - good morning! Well Matt, my 944 is an '86 with a replacement '84 engine due to the fact that I blew the original motor. I upgraded the water pump because the old one began to leak. The new design calls for the belt guide so, frankly, I don't see why you believe that it should be a concern.
The idler in the photo is the one recommended for the newer water pump. But, given that I replaced all the idlers and pulleys last month, it's all water under a bridge.
BTW, the car worked great after the re-build but I am now trying to figure out why I have no oil pressure at all. I have fresh oil, filter, primed the pump, torqued the crankshaft bolt, etc. so I'm replacing the oil pressure relief valve as a first diagnostic step. I'd hate to have to take the oil pump apart or replace the oil pickup tube. Wish me luck!
Original owner, 1986 944 Guards Red/Black
Old 09-23-2015, 06:19 AM
Sending unit?
How do you know you have no oil pressure, is it because there is no reading on the dashboard gauge? If so it could be the oil pressure sending unit or even just the connections. Hope it is as simple as a wire left off; I love those fixes. Good luck.
1988 Silver 924-S Original owner
Porsche 924S: The 944's cheaper, faster little sister.
Old 09-23-2015, 10:50 AM
88Silver924S -- I wish it'd as simple as the pressure sensor or a loose wire connection.
I don't want to hijack this thread but even prior to the timing belt disaster, I've been getting very low pressure at cold start for about 30-45 seconds and then normal pressure. The pressure would remain at normal until the following cold start.
As I mentioned earlier, I had to replace valves, etc. because of the tensioner failure this past summer. When the repairs were completed the engine started fine and the major repair was a success. Pretty proud of myself if I may say, but the low pressure at cold start & then OK issue continued since it obviously was never addressed.
About a week ago the pressure would never build up at all even after a couple of minutes. I dared not drive the car and have been searching all Porsche forums for answers since. Some say to replace the oil pressure relief valve, others to prime the pump and others point to the oil pump or pick-up tube.
Since inspecting/repairing the pump and pick-up tube require lifting the engine and are a major undertaking, I've opted to replace the OPRV and re-prime the pump this weekend as a first step to see if I can spare myself major headaches.
Wish me luck!
Old 09-23-2015, 11:26 AM
In the Fires of Hell.....
kdjones2000's Avatar
Delayed pressure and eventually loss of pressure are exactly what happened to my race engine when the balance shafts were out of time.
The end result was a spun bearing, broken rod and holed block.
Root cause was cracked oil pick up tube... very hard to see unless it's out of the engine.
/ thread hijack...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 09-23-2015, 12:15 PM
