Question 944S/968 manifold and injector questions
Will the injectors from my 87 944s work on my 92 968 engine? I ask because I am considering having my 968 injectors cleaned and flow matched. I have the old injectors from my 87 944s allready out of the car. Can I just send them out, so there is no down time for my 968?
Also, I know the ouyter exhaust manifolds from same are different part#'s. However The "S" will work on the 968...my question is Are they diffent interior diameters, Is one more free flowing than the other
Old 11-23-2002, 02:18 PM
AFJuvat's Avatar
Fuel injectors: No you can't use them.
Manifolds - no idea, never measured them.
AFJuvat
How is the battery problem coming?
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-25-2002, 10:36 AM
Thanks, I figured not but I thought I'd ask.
It ends up it was indeed my alternator. I replaced it and all is good. Also,iIt seems my mechanic had installed a PK 1000 belt and I needed the shorter 990 version. The shorter belt solved my slippage problem as well.
I just got Koni yellows on the rear, now I need to get some for the front and I am also considering installing a "Euro" rear valence. I found a good used one cheaper than the new GT- Racing one, However it does not include the mounting bolts od hardware. I am not sure where I can get such mounting hardware. Any sugestions?
Ross
Old 11-25-2002, 10:52 AM
