1987 944 Turbo Camshaft Sleeve
What is the correct part number for the camshaft sleeve on my 1987 Porsche 951? I've seen either 928-105-139-02 or 928-105-139-05. I'm pretty sure 928-105-139-02 is the sleeve for the upper and lower balance shaft seals, however can it also be used for the camshaft?
Our Pelican overlords say you need to check your engine number.
In the Fires of Hell.....
You will also need the later seal for your sleeve.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
