Need some ignition advice
I've finally gotten my 85.5 running but the only other issues I'm having now is my instrument cluster is hit or mis as far as working. I messed with the connections with no luck but now found out that it seems to be related to the key turning in the ignition!?!? Does this make sense to anyone ?
Old 10-06-2015, 04:34 PM
jhowell371's Avatar
Ignition switches are a known source of such problems.
Red 84 w/25,xxx miles
Stone Gray 89 S2 w/90,xxx miles
Old 10-06-2015, 05:28 PM
Proprietoristicly Refined
John_AZ's Avatar
+1
Replacement info:
Ignition Switch Replacement
Clarks also has a ignition test procedure.
Clark's Garage Home Page
J-AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-06-2015, 05:50 PM
I was looking into replacing it but it's showing two different parts of the switch not sure which to get.
Old 10-06-2015, 08:00 PM
John_AZ's Avatar
Usually on 85.5 & up, this is the faulty ignition switch-$108:
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
On early 944 & 924S -cheap $5
J-AZ
Old 10-07-2015, 06:30 AM
