Jacking Points on 968
Using my floor jack, where are the jacking points to raise this thing off the ground. I'll have to use my RV stacking squares and/or 2x6's to drive up on just to get enuff room to slide the floor jack under there, just need to know the safe areas to use the floor jack.
Jacking 944S2 Cabriolet - Rennlist Discussion Forums
the 968 has a similar floor to the S2 cab...mostly flat. there are a few spots where its safe to lift though. |
the 968 has 4 built in jacking points. they are plates with oval holes in them. any race jack should fit under there fine.
Do NOT jack and the front subframe; it will bend!
| All times are GMT -8. The time now is 04:10 AM. |
